KA bore'd 0.040 over too much??????
Old Mar 23, 2008 | 08:27 AM
quiksilvia's Avatar
im just lookin for like 250 whp....
id say
10lbs???
VV Pasco Meet every friday! VV
Awesome Pasco Car meet evey Friday!
Originally Posted by EclipseGT01
Try and get people at ANY car show to come around a Grand Prix or a Regal.... they simply wont because there is a lack of interest in those cars. Not saying they can't be fast... just saying that my WRX will always attract more pussy than your pontiac
[Insert Awesome witty car list here]
[§]Hellabroke Ballin aint free! [§]
Old Mar 23, 2008 | 11:46 AM
GlacierFreeze's Avatar
Outta Towner :)
If 250whp is all ya want then .040 should be fine. Get a GT28R and a ROM tune and you're good to go. 13s easy.
Angry Video Game Nerd =
Originally Posted by moldyhands
Originally Posted by Strangeholliday
To me " old fashion values and morals " just means hes prejudice and believes a woman's place is in the kitchen, That shes not equal to men, and can't open her own door...
how are those values? that's just physics man. can't argue with physics.
Old Mar 23, 2008 | 06:06 PM
norachelhere's Avatar
fails.....
Originally Posted by Mars_302
a torque plate is a plate that sits over the engine block where the heads go and they torque bolts down to replicate how the cylinders will change when they actually being torqued down with real heads and bolts. They then bore it.
giving you a more accurate bore, lowering the chance that the block will flex when the head is put on, which would cause all kinds of issues...
good to know.
Old Mar 23, 2008 | 06:24 PM
180SX's Avatar
#1 A torque plate is not as necessary on dense (import) iron motors as it is on a alum motor like a SR
#2 40 over is not too much.. and it has nothing to do with reliability
#3 check your ring gap and piston to wall clearance before you assemble
#4 if in doubt about your motor assembling abilites see my sig, it will save you time and money
Martin
Old Mar 24, 2008 | 06:45 AM
quiksilvia's Avatar
martin you have a Pm!
Old Mar 24, 2008 | 09:25 AM
Outta Towner :)
Haha don't feel bad because I'd be doing the same!
Old Mar 24, 2008 | 02:08 PM
  #17 (permalink)
quiksilvia's Avatar
sounds good........ but 1000 to build w/o install is alot
and only using OEM bearings when i have clivette main and rod bearings
Old Mar 24, 2008 | 07:49 PM
  #18 (permalink)
dan's Avatar
dan
Get the fuck off my lawn
OEM bearings are almost preferred in most builds not exceeding ludicrous power.
ive seen KAs bored .060" over in a few extreme cases and they were still fine, but i wouldn't go out and do that so you can have a big bore motor
the key is to bore it the least you can, but in many cases, especially during failed engines, is that boring past .020" is needed and thus .040" is the next step.
dont worry, when a KA block breaks, it won't be between cylinders...it will be out the bottom portion of #1 hehehe.
Old Mar 25, 2008 | 06:38 PM
  #19 (permalink)
In_DET's Avatar
I sent #3 rod through my block when my KA went. I bought it with a rod knock with the intentions of seeing what it could take. I beat on it for a month, clutch dumps, burn outs, etc before it let go, but when it did what a noise. I blew a chunk out of my block big enough to see #3 and #4 rods, bent the hell out of the oil pan, and broke a big chunk off of my bellhousing.
Old Mar 25, 2008 | 06:42 PM
  #20 (permalink)
fails.....
that would have made for a great video...
I wanna get some little cameras rigged up under the hood and then do whatever it takes to blow the motor violently....
It would be even more badass to have High speed camera too. Actually get to see the block bulge and break and pieces go shooting out.
