Problems
Hey ppl i have a 200sx se with the sr20det in it and im getting noise from the bottom end and was needing help. I cant do any of the work where i live out in Holiday. This is my first nissan and my first turbo set up all help will be great.
well he cant do the work himself anyway, after he would pay someone to do his internals, IF the block and crank are fine...just get a shortblock if anything
i have taken apart motors for hondas. im just prayin its just the bearings and nothing else.... i just dont have a place to do the work and would like someone with knowledge of nissan to be there just in case i have ? or to help out..
I live just north of you, depending on when you plan to do it. I most likely will be able to help...
i havent driven it since then its sittin right now. i just need to pull the motor and put it on a stand and then see wat is wrong and go from there. so IThaJokaI if you want you can swing by today and ill explain in person what happened. hit me on aim msn or yahoo. names following order are jjsk8ter, gen2teg2002@hotmail.com and yahoo is jasonn_cadstudent
ah i love these motors
which motor did you have in there? Avenir...Bluebird..or the nasty GTIR
i lost the bottom end in my GTIR some time back...was no fun...if you were closer i would love to help you out.
if you want you will get a lot more help by going here:
www.sr20forum.com
they have a whole florida section with a lot of tampa st pete guys...one guy on there brian is a real good guy and should be able to help you.
check it out man its way worth it...plus a lot of people there are mainly FWD sr20det
g/l and hope it works out
www.sr20forum.com
