ka24de issues pt.2
Old Jan 22, 2008 | 01:45 PM
Crav3n Mo0r3he4d's Avatar
Thats it and thats all
Default ka24de issues pt.2
well I posted a while back about my ka acting up but the plot thickened today. I have since the original issue went through all the basic cheap easy fixes such as: plugs, wires, dis. rotor, fuel filter etc. and still had the running on 2 cylinders issue ocassionally on warm starts. so today it wouldnt fire up at all but it would turn over. i tried for about 30 minutes with out luck then instead of givin it a little gas i put the pedal to the floor and crank it and it starts. im thinking it may be the tps, or something with the fuel system. i was just curious if anyone else may have an answer. i greatly appreciate any help. its a obd2 95ka btw.
Old Jan 23, 2008 | 11:15 AM
norachelhere's Avatar
fails.....
are you getting spark on all cylinders?
fuel?
if you're getting everything like you should, then it sounds like it could be a nasty vacuum leak....
Old Jan 23, 2008 | 03:45 PM
well im hoping to narrow it down more tomorrow. it ran perfect today until about an hour ago. it did the exact same thing then eventually fired up once i floored it. im almost sure its something simple, like you said it may be spark or fuel. i did a compression test recently and ran 200 across all 4 so thats good, and did the things listed above. im gonna upgrade the fuel pump while im at it tho and plug it up and get a reading cause it is obd2. appreciate the feedback.
Old Jan 25, 2008 | 01:38 PM
fails.....
anyword?
Old Jan 26, 2008 | 08:22 AM
well as of right now shes been runnin, but i know the problem is still not fixed. im gonna pick up a walboro today and try that out. for some reason i think its not gonna be the fix tho. im also thinkin maf could be screwy so ill probly replace that next and give her a good ol sea foam treatment. i checked the vac lines and they all seem to be in place. ill let you guys know, and if anyone has anymore suggestions please lmk. thanks
Old Jan 28, 2008 | 03:02 PM
well again today same thing, ran great then wouldnt crank on a warm start and finally did after keeping the pedal floored. i got the walbro just need to install i also picked up some mafs cleaner. i tried pulling the fuel pump fuse today to get it started and no luck that rules out that issue.
