Car wont idle on decel...
Old Nov 17, 2007 | 09:28 PM
Nismosil40zx's Avatar
Default Car wont idle on decel...
Greddy intake z32maf enthalpy tune are the basic mods and know I cant get it to idle on decel or when I come to a stop it likes to try and die sometimes. Any ideas. thinking iac or tps. Really just fed up with the car.
GT35r
264 cams BC
Greddy Intake ported
Tubular Ex. Manifold
safc 2 and enthalpy tune
740 cc injs
z32 maf
1990 coupe 240sx red top
Old Nov 18, 2007 | 04:42 AM
marble hatch's Avatar
i can has 30r plz?
what car / motor / mods? details son we need them
(O=O/-180sx-\O=O)
Old Nov 18, 2007 | 08:08 AM
-weekendwarrior-'s Avatar
Army Infantry
it could be many things but i'd check for boost/vac leaks first cuz mine will do that sometimes and its always a coupler that works its way loose
also if your car doesnt idle at 900rpm then bump up the idle till it does that should help
Old Nov 18, 2007 | 08:22 AM
No leaks already check tighten all t-bolts and did a smoke check. nothing.
Old Nov 18, 2007 | 08:30 AM
Army Infantry
hmm. if you have volt meter check the volts on the tps and make sure they go up when you rev the car and they are steady. i dont remember what volt is normal but when mine went bad it dropped volts like crazy. if martin sees this i hope he'll post he would know
Old Nov 18, 2007 | 08:51 AM
RyanS13's Avatar
doin big thangs
raise idle?!
Old Nov 18, 2007 | 01:17 PM
I raise it to 1500 which is the only place it will stay andnot die but that is a little high.
Old Nov 18, 2007 | 01:21 PM
Army Infantry
yeah you shouldnt have to put it that high. you need either a idle air controller or tps. probably a iac and if theyre both good go pick up a ids (idle defense system) apexi makes them and theyre around 100$ and they work very well
Old Nov 18, 2007 | 05:21 PM
....Show me a link of this Idle defense system that Apexi has. never heard of it and cant find it. Plus Y would I need that I should justbe able to fix it with out another bolt on. Im starting to think it is enthalpy tune..It wasnt like that until i got the ecu back from them.
Old Nov 18, 2007 | 08:53 PM
Boats N' Hoes's Avatar
i think the safc 2 has a decel counter....its a mod specifically for slowing down and avoids stalling
Originally Posted by CurbJacker
great a new fucking band wagon... now every fucking 240 and ricers gonna be saying " im going LS1" i hate this shit... ill stick to SR20... teenie bopers i swear.
So_Chem WE RUN SHIT!
[/CENTER]
