Car wont idle on decel...
MAF is about 8 yo 10 in away from turbo. Enthalpy has a good tune but it is a little rich for me so I try and fine tune it a little better with a safc2 (10.0 and 10.5 wot) little rich
maf is a little too close to that snail for proper idle. have you tested decelerating without the safc?
call and make an appointment at XAT for a re-flash on the dyno. it shouldn't take much to fine tune. dyno tuning is $100 per hour.
ok..
1. Go into 2. Settings or 3. ETC menu (can't remember which)
2. Click next on "Decel. Air"
3. Set "Thr." to 5%
Set NE1 to 1.4
Set Ne2 to 1.3
Car should not die at all.
Tighten your BOV as well !!!!
Also make sure you have a 90 degree coupler or bend between your MAF and turbo inlet. The straighter the intake pipe, the worse the problem will be.
Martin
3. Set "Thr." to 5%
Set NE1 to 1.4
Set Ne2 to 1.3
Martin
Do what 180sx said, he is my tuner. Only I would throw out the BOV instead of tightening it.
I agree. You will spend more money and have more problems. Sure the ems has more features, logging, channels, etc. The rom tune ecu is more reliable and it's simple stupid. I have even heard of guys switching back to the rom tune from a standalone for the get er dun simplicity.
"Rom tune so easy a cave man can do it."
$2000 wow someone got ripped off. Do you want to buy a 240 they seem to me they are junk 1000 wheel cars that run 9.0 sound pretty weak to me. Just tired of messing with it. it gets old.
