ka cam sprocket
So im completely lost when i got to this point, motor is TDC and the sprockets dont want to go on. Advice?
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
they can be a pain even when everything is lined up. I found getting someone else to hold the cam helps you to eye ball the sprocket with the little notch and then get it on. it isn't really a two person job, just a three handed one... lol
i forget what size wrench you need, I just used an adjustable one, behind the first bracket, the cam shaft has flat spots where you can put a wrench so you can rotate the cam shaft, and hold it where you want it...
