95 240sx throw-out bearing question
Old Aug 19, 2007 | 08:01 PM
chask's Avatar
NEVER LIFT!!!
Default 95 240sx throw-out bearing question
if i have a noise in my 240 when i press in the clutch is that my throw-out bearing or is that something else.. and if it is my bearing how hard is that to replace?? and the cost?? just wondering
Old Aug 21, 2007 | 03:21 PM
Lwclrnce06's Avatar
i had a car that did the same thing u need a throw out bearing. depending on where u go to how much it would cost
Old Aug 21, 2007 | 03:23 PM
+Waldo+'s Avatar
Electronicals master ;P
its not difficult to replace bud, but it is a couple hour job seeing on how u will need to remove entire tranny
but it could be a couple things, so research a little more before confirming and doing the job
good luck!!
Sponsored By Carrabba's
R.I.P. Tim Aldrich
Old Aug 21, 2007 | 04:01 PM
norachelhere's Avatar
fails.....
a throw out bearing, itself, i'm not sure, but you can always get one from the junk yard.
it isn't hard to replace, you just have to pull your tranny.....
good luck
Old Aug 21, 2007 | 04:04 PM
+Waldo+'s Avatar
they come with clutches usually, but im sure you can buy one they cant be much so i wouldnt go junk yard...
and hows your clutch feel? maybe go ahead and replace while you got everything off
R.I.P. Tim Aldrich
Old Aug 21, 2007 | 04:13 PM
TurboJdmEk's Avatar
is on blocks...
ok, i jus bought one for my ka tranny for 20 brand new from autozone, but the noise should stop when u press the clutch most likely, but itll cost bought 100 bucks to put in
its coming...
