A/C into an S13 w/RB20DET
Old Aug 7, 2007 | 07:49 PM
onezx2ner's Avatar
is on the move
I believe you can use the KA compressor and some guy had some brackets made on NICOclub I saw. The only line you need custom is the one that runs behind the engine.
I have a rb20det sil80 and it doesn't have power steering or a/c, so I bought another car this weekend with a/c. Shit is hard to go without in FL.
Old Aug 8, 2007 | 04:11 AM
orochinoyamato's Avatar
I find it slightly frightning that it was easier/cheaper for you to buy another car than to install A/C--but thanks for the pointer to NICOclub. Perhaps I can get the guy's measurements for the fabricated part and take it to a machinist friend somewhere. Once I make a machinist friend.
Old Aug 8, 2007 | 05:12 AM
BluRRboSi's Avatar
35.5 psi, stock sleeves
You will have to get the rb compressor. Unless you wanna pay for someone to fabricate it up.
Weld the rb ends to the ka lines, change drier, then wire so the damn thing doesnt wear out in 6mo. & good to go.
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
Old Aug 8, 2007 | 08:09 AM
Thanks--Any idea if XAT wires in that switch when they do yer stuff? And, if I got the custom bracket for the KA compressor, would there be any other difference besides the line ends that get welded on?
Old Aug 8, 2007 | 11:43 AM
onezx2ner's Avatar
is on the move
You got me, I just wanted a reason to officially make my rb20 car a track car and have aonther to drive on the road.
Old Aug 8, 2007 | 04:56 PM
180SX's Avatar
yes.. we wire it from your facotry switch to your ECU, so it shuts the compressor off at WOT or high rpm like a OEM nissan.
Martin
