not starting.
Old Aug 8, 2007 | 09:17 AM
doodoobrown69's Avatar
Stinky Pink
Default not starting.
SR
got my starter checked out, auto zone said it was bad, but i took it to a specialty shop that only does starters, they said it was good.
i put the starter back on and its doin the same ish, not turning over, not even clicking.
CFP has a starter for $150, i was thinkin i could give him 150 and put that starter on the car and take it back if it doesnt work,
it seems like the starter cant spin the flywheel, like maybe the flywheel is stuck or somethin is wrong with the engine.
We Hope You Enjoy The Motor Sports!
Old Aug 8, 2007 | 09:21 AM
Ph34r's Avatar
ΔxΔp ≥ h
Can you push start it?
Might be the Engage spring in the starter, try tapping the back of it with a hammer or something to try to unstick the piece that pops up into place.
Old Aug 8, 2007 | 09:33 AM
Ronald Mcdonald's Avatar
Shakotan/Hippari life.
Try pop starting it.
That might help give you an idea as to what it is.
Did you make sure your battery isn't dead?
-'03 GSX-R 750
Old Aug 8, 2007 | 10:00 AM
Stinky Pink
i just got a brand new optima yellow top so that should be good, and i put the charger on it to make sure and that didnt change anything,
i tried to push start it and it turned over but didnt start.
Old Aug 8, 2007 | 10:20 AM
+Waldo+'s Avatar
Electronicals master ;P
if you tryed push starting it, and it still wouldnt start... i wouldn't think thats the starter then....
maybe something more...
Sponsored By Carrabba's
R.I.P. Tim Aldrich
Old Aug 8, 2007 | 10:21 AM
oASHo's Avatar
Lace Up!!!
take a bat, and beat on starter to engage taht little piece, then try starting it, and then let us know what happens.
Old Aug 8, 2007 | 10:23 AM
k4rr's Avatar
Who's bicycle is this?
I got a SR starter!! I can ship it to you for 75.00
Old Aug 8, 2007 | 10:44 AM
727 GST's Avatar
fake it til ya make it!
it may be the relay? not to sure about nissan's though.
I had basically the same problem on my mitsu GST. We bypassed the relay and made it a push button start. All I remember doing is running a line from the battery to the push button, and push button to the starter. And another line from the starter to a ground. Put the key in and turn the ignition on then push the button and it cranked up fine.
...just a thought
Old Aug 8, 2007 | 10:56 AM
Stinky Pink
...just a thought
that makes sense.
i tried swaping out the relay, didnt change anythign,
when they tested the starter it popped out and spun
Old Aug 8, 2007 | 11:12 AM
Matt Vassallo's Avatar
lifelong learner
ive got like three starters here if you need one also.
bring your piece of shit over and i'll fix it.
rest in peace tim.
