i have a question??
Old Jun 13, 2007 | 06:22 AM
lazaro240sx's Avatar
Default i have a question??
does the performance chips really work or is it just bull ?
Old Jun 13, 2007 | 06:26 AM
RaidenKing's Avatar
don't waste the cash on a chip that fools your car into thinking you're giving it more throttle when you really aren't.
not worth your money.
7! pints of ale out the window sill
when I get my fill I'm chilly chill
Old Jun 13, 2007 | 07:17 AM
norachelhere's Avatar
fails.....
yeah... 98.9734% of all of those performance chips just alter the signals sent to the ECU so the ECU thinks that it needs to dump more gas. Sure it makes some more power, but not the way you want to. you'd be better off spending that money on getting a real tune. even stock engines can get a little bit out of a good tune.
Old Jun 13, 2007 | 07:18 AM
fails.....
oh and anyone that tells you that those chips do all sort of amazing things and make 50 HP and all that crap, probably drives a POS domestic and thinks he's fast because its a big engine...
so don't listen to them...
Old Jun 13, 2007 | 08:33 AM
robsr20det's Avatar
for a ka24de they don't make much of a difference. intake, headers, exhaust and a good set of wires and a crane cams coil will probably do better than those chips. or put it on a dyno and see how's it doing.....
Old Jun 13, 2007 | 08:43 AM
i have intake all that good stuff but the ka24de doesnt have that much power wat are some upgradeds so it was more horse power other dam turbo?
Old Jun 13, 2007 | 08:50 AM
maddreject's Avatar
That exactly what ya need to start with.
Old Jun 13, 2007 | 09:06 AM
fails.....
intake/headers/exhaust.
lightweight pulleys
lightweight flywheel
dual exhaust cams
single cam pistons
z32 maf
(or ITBs if you're really going for it)
some major tuning
there are plenty of little things (and big depnding on how you look at it) to add power, the question i have for you is, how much power are you looking to get and how much money do you have?
if your car has alot of miles... better yet.... if it has more than 75,000 miles, then rebuild it. a heathy engine makes more power than an old beaten down engine....
