S13 Wiper question!
ok so i got everything hooked up correctly and motor works but for some reason wipers not working is there something i over looked? im pretty sure i got everything hooked up! and the wipers switch works cause it did in my last car... what should i check for just a little lost right now.
does the motor make noise when you move the wiper switch to on? if you hear noise but no movement, wipers may be loose, or there could be a linkage issue under the front cowl area. if the motor doesn't make noise, and you have voltage at that connector, replace the motor.
NOBAMA!
NOBAMA!
