help with s13
Yo the car gets warm and the car dies, because the ecm is choking the engine till it gets to operating temp, while its doing that the engine idle is compromised, so even if the timing or idle is off you wont know until the engine is warm! do you understand? if not i work at S&R Performance, and i drive and s13 i can help you. names JEFF
check:
Coolent temp<----actual temp reading not the sensor
ecu plugs
air fuel ratio
fuel pressure
IAC valve
if no luck pm me or call the shop!! 961-0609
check:
ecu plugs
air fuel ratio
fuel pressure
IAC valve
not trying to start an "e-thug-a-thon" or anything like that.
^ damn cant we all just get along.... i mean shit we mainly all have somethingin common..... we all have nissans so shit might as well be nice lol
but anyways back to the question. if its smoking at all than you might wanna have your head gasket checked out, cause mine just blew and thats what was happening. like the idle was shit. so that might be a possible solution
People Call Me Cool When Im Driving.... But Theyre Only Refering Too My Car...... So I Feel Bad
www.myspace.com/thomasmsanders
