Attn: 240sx Troubleshooting Gurus, Help needed
would that happen if it was running lean for a while (not sure how long but several miles at least)
I'm thinking timing issues too, but everything seems to be were it is supposed to be. The cams point away from each other, when you line the marks up on the crank pulley. And according to my FSM and the pictures I can find online, I'm setting the distributor correctly.
I hope this is something obvious that I'm just over looking.....
I don't think I realized that.... now that you point it out, it makes sense i think.... it would be TDC of #1 every other time it lined up right? That means that I might be setting the dizzy at TDC of #4?
I didn't think the ratios would let that happen, but maybe i missed something.
thanks, i'll double check that in a bit
yea...you need TDC on the compression stroke. There is TDC compression stroke and TDC exhaust stroke. Take out the all the spark plugs and put the plug wire in #1 cylinder (w/out spark plug), and turn over the crank(better by hand) when the plug wire pops up your on the compression stroke, after that just set it on TDC and recheck distr. Hope that helps
I have to wait for my tools to get here, they are in the back of my buddies hatch. then, i'll be able to check a few things, double check the dizzy and get back with you guys on the status
thanks for all of help
art
IM IN VA BITCH!!!!!!
www.rccustomz.com
www.rccustomz.com
+1 with taylor
More helpful hints for timing:
Remove the valve cover and make sure the cam lobes are facing away from each other.
Line the marks on the distributor up with each other, and insert into the timing cover.
Look down the timing cover with the valve cover removed, and make sure the marks on the distributor are STILL lined up.
I have noticed that you typically have to slighly offset the marks from each other so that when the teeth from the distributor engage the teeth from the timing chain idler pulley, The marks will line up.
Hope this helps!
Hope this helps!
+1 with taylor
Hope this helps!
Hope this helps!
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
i know right
anyway, the latest update.
I wasn't there so I don't know this for a fact.
My buddy was working on the car and he said that he double checked everything and lined everything up. The spark plugs were sparking. Time was set at the correct TDC. The whole nine yards. He said that he couldn't get it to start. He got some "pops" but not enough to be running.
I don't know if he actually got everything the way it needed to be or not.
We also realized that the gas has been sitting in the tank for a while. I'm wondering if that is the cause. I know it was 92 octane, a few months ago.... maybe last august.... ok so maybe it was more than a few months, more like 8. Would the gas just not be any good? and would it cause this issue?
thanks
um I had 6 month old gas and it started right up but i probaly got lucky. If its poping then its just your timing, try to turn the dist. to the left i believe i think the dist. is to advance...Try that.
i've turned it all sorts of ways, still no luck. i'm gonna try and see if the injectors are actually putting out the proper amounts of gas.
anybody know of a better way then to hold the fuel rail off to the side and make a mess?
