help
Old Mar 10, 2007 | 05:14 PM
chome's Avatar
Will sleep for food.
Default help
How do I take the check engine light off when it is caused by the speed sensor?
Old Mar 10, 2007 | 05:22 PM
dan's Avatar
dan
Get the fuck off my lawn
why is the VSS giving u a CEL?
you can turn the screw on the ecu to reset it but that code will probably show back up in a few minutes.
Old Mar 10, 2007 | 05:26 PM
chome's Avatar
i just got a 5speed swap done by dc. and they said the speed sensor or the crank shaft sensor turned it on. how do i turn it off forever or fix it
Old Mar 10, 2007 | 06:23 PM
norachelhere's Avatar
fails.....
fix it, replace the bad sensor
get rid of it, disconnect the battery, count to 20 and hook it back up (counting to 20 not required, you just want to make sure that the ecu has enough time to forget everything...)
Old Mar 10, 2007 | 07:13 PM
chome's Avatar
thanks for the info guys. ill try everything when i get home and ill give usome feedback
Old Mar 10, 2007 | 10:52 PM
dan's Avatar
dan
are u using auto ecu still? usualy the wiring takes care of it, but if its the crank position sensor (which im sure it could be since its obd-2) u can just unplug it. or plug one in if the tranny has the hole up top for it. its diagnostic only so no worries except the annoying light.
Old Mar 13, 2007 | 11:57 AM
chome's Avatar
im get a 5speed ecu soon. will that fix it
