Electric radiator fan suggestions for a KA-T.
part 2
Electric fans
Engine-driven fans can get the job done when you’re tooling down the highway at cruising speeds, but when you’re idling or fighting stop-and-go traffic – not so much. For increased cooling capacity, consider installing an electric fan, or two.
Unlike an engine-driven fan, an electric fan is going to generate enough airflow to sufficiently help cool the engine, regardless of engine RPMs or traveling speed. In addition to consistent airflow, electric fans can also net you more horsepower. It’s estimated that engine-driven fans steal about 35 horsepower and clutch-driven fans about half that amount while electric fans only take about one horsepower.
Installing a dual-fan set up enables the entire radiator surface to be covered with cooling air flow. Another option is to use a two-fan system, but with one fan stationed in front of the radiator, pushing air to it, and a second fan behind the radiator, pulling air to it – remembering that pulling is always more efficient than pushing.
As for fan blade style, that depends on what’s more important to you – cooling or noise levels. Curved-bladed fans are quieter than straight-blade fans, but they don’t move as much air.
And in what’s probably beginning to sound like a reoccurring theme, a changeover from an engine-drive fan to an electric one might also require some beefing up of the vehicle’s electrical system to ensure it’s up to the task and increased loads.
Fan shroud
If you’re making the effort of adding an electric fan, make sure you go all the way and include an aluminum fan shroud. The right fan shroud can maximize the fan’s heat-reduction capacity by delivering cooling air to nearly every square inch of the radiator surface, while choosing aluminum helps deliver further weight reduction.
Type of Coolant
When it comes to the liquid flowing through the radiator, nothing’s better at heat transfer than plain old water. Unfortunately nothing also beats water when it comes to freezing in winter and destroying your engine, and corroding the radiator and inflicting a similar level of carnage there. If you are running straight water for coolant – some racing series require this – be sure to also include an anti-corrosion additive to the mix, and to take the necessary steps to prevent freezing before lower temperatures arrive. You’ll also need to research the benefits of using softened water if this is the somewhat risky route you choose to go. If, however, you choose to play it safe by using traditional antifreeze, also consider an additive, such as Red Line’s Water Wetter that prevents bubbles or vapor pockets from forming and helps bring temperatures down.
Electric fans
Fan shroud
Type of Coolant
