removing crank pulley ka24de
what does it take? will just an impact gun work? are they backwards threads or anything weird i should know? do i have to heat it up? any special tools.....basically i need it off and i dont wanna get stuck missing somthing i need, so if anyone could tell me that would be great.
it depends on how much of it you want to take off.
the front part of the pulley will come off with 6 10mm bolts but the other two pulleys in there you have to take out the crank bolt. i believe its a 27 mm. idk much about using impact guns but i know a breker bar with maybe a lead pipe extension should get it off for you. thats what i used.
and no, theyre not opposite threaded
Nissan North America - Canton
if u dont have an impact gun get something like a pry bar or something that u can wedge inbetween those little little holes on the pulley have someone keep it from moving while you break that nut loose. this is the harder way but it does work.
Jonas
Jonas
doesn't work.
Jonas
Jonas
I did it by puttin it in gear and ebake on. what i used was a 36" 1/2" breaker bar and a nice long pole. someone keep pressure on the socket so it stays striaght and doesn't strip, the other person pulls on the pole.
rusty an shitty
