sr to tranny swap
ok so i am taking my sr tranny out and i need to know what is the best way to get to the bolts on the bell housing cause OMG its hard and is there anything i need to know about puttign the ka tranny in its palce besides swaping the bellhousing??? thanks
wedge soething between the downpipe and the bottom of the frame, like possible a small scissor jack it will angle the motor down a little to give you some space to get to the top tranny bolts. where do you live, lets do our tranny swaps together.
it sucks without having a lift.
you can get to all the bell housing bolts with various extensions and swivel joints. Luckily the SR doesnt have a bolt at the "12 o'clock" position (like KA), instead it has one at both the "11" and "1" position- but they still are not fun to do.
when you go to put the trans back on the engine this (quote) helps alot.
^this will angle the rear of engine downward and become your BFF (best friend forever)
IMO without a lift, I would rather pull the entire engine/trans out and then work on it, and reinstall the entire engine/trans.
or u can just have all your tools lined up, jack up your car as high as you can with jackstands and bench press a little and use another jack to help lift up the tranny. this is ideal with 2 people. it's not that hard.
You can get to all the bolts pretty easy from under the car, and the top two use a wrench from under the hood. it takes me about 30 minutes to remove all the bolts from the belhousing. And yes extensions and a swivel joint will be your best friend in this project.
Also, I usually remove the upper bolts first then the lower ones.
Team White Car 2010
Team White Car 2010
yeah so we got it in and guess what the tranny is not good that i bought!!!! it wont go in to gear and whenits in neutrual thats 2nd and then it will go to 5th spot but wont actually go in pretty pissed
