I will rebuild it so it's stronger and faster...
Old Nov 14, 2006 | 05:15 PM
RoadRacer's Avatar
Turn 7 at Sebring
Originally Posted by ImportLuv
Cliff Noted it
Still makes sense, saves everyone 10 seconds of their life.
Here's your
and some help finding a job
Find Jobs - Editor Jobs in Tampa, FL
Patrick -
Old Nov 14, 2006 | 06:12 PM
Epstein's Avatar
Retired
And while the head is off, you can address having water lines behind the head. I have a neat heater delete setup from Trogdor that you should run. Plumb the turbo coolant return into the water neck, cap off you iacv coolant loop, and you're done. Let me know if you need anything.
If you want to get an Apexi, call up Phase2. I had no problem getting 2 of them immediately. They even sorted out the boxing problem that Apexi has been having.
Old Nov 19, 2006 | 07:30 AM
I'm Phucked's Avatar
army pilot
me and a few others are in need of a head gasket (the better one of course) could there be a group buy or am I too late?
In a relationship you are either man or woman choose wisely [fortune cookie @ Ling's garden]
Originally Posted by Tackleberry
thats an insult to a circus
Old Nov 19, 2006 | 07:16 PM
180SX's Avatar
Patrick,
If you are warped that bad, then you should check your bore distortion... Make sure you still have cross thatch on the bores so that you're rings are not siezed from the high temp piston expansion.
Martin
XAT
Old Nov 20, 2006 | 04:19 AM
RoadRacer's Avatar
Turn 7 at Sebring
Thanks for the information. Dan if this happens again I am calling you!
Epstien, I will get a hold of you. Thanks Martin, If I have any questions I will call you.
Patrick -
Old Nov 22, 2006 | 05:05 PM
CFP_IVAN's Avatar
CFP was...
we will rebuilt it better and stronger than ever. patrick has really good skills at the track. fun ride along.
