issues with the 240.
Old Aug 16, 2006 | 10:47 AM
lordofthemiasma's Avatar
RIP DJ YOU WILL BE MISSED
Default issues with the 240.
workin on a freinds car and we are stumped? car turns over but sounds like it is being run by the starter. few little pops out the exhaust and thats it. It has fuel and spark but sounds like no compression. All fluids are good....no blown headgasket.
any ideas????
RIP my very best friend. DJ aka djzstang1 you will be missed dearly. I love you bro.
1995 240sx se
1992 240sx
1990 240sx se
1991 240sx hicas sr20det MDX
1991 240sx project coupe
1990 240sx drift beater hatch
1993 240sx sr20det
Old Aug 16, 2006 | 11:28 AM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
mmmm poundcake....
god damn the guy that fills the vending machine....
no poundcake having motherfucker.
oh yeah back on topic,
Check ecu and see if its tightened down.
You sure your getting spark?
Check timing and advance if retarded, per the FSM (I assume you have a copy laying around)
Otherwise come back with a little more info...
(you try kicking it?)
Bad gas?
How long has it not run?
Dual cam or single?
Swap or OG motor.
More info would help the online diagnosis.
Buying/Selling on TR is like shaving your ass before going to prison. You know your gonna get fucked, you just try and make it as pleasant as possible.
Old Aug 16, 2006 | 11:41 AM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
holy fuck read much?
let me post again oustide of the drama shit.
Bad gas?
Dual cam or single?
Swap or OG motor.
Old Aug 16, 2006 | 11:43 AM
Originally Posted by ph0tek
mmmm poundcake....
Bad gas?
Dual cam or single?
Swap or OG motor.
twin cam, og motor, hasnt run in a few months, gas smells and looks fine, tried kicking it several times,got spark, did timing several times, swapped ecus... car was bveing drivine down the interstate at around 60-70 mph when it died... hasnt run since then......
1995 240sx se
1992 240sx
1990 240sx se
1993 240sx sr20det
Old Aug 16, 2006 | 11:48 AM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
THe motor cranks though? as in its not ceased up?
Try starting fluid?
Honestly as I just heard about this earlier today, the ECU harness plug can sometimes flex and not make contact. Make sure its tight bolted back in and press down on both sides while trying to start it.
If it stopped while driving, it sounds electrical as in a wire somewhere melted or came disconnected, it ran fine before this?
Check the oil (for metal) or have a compression test done?
Old Aug 16, 2006 | 12:18 PM
yeah i agree on the elct thing.. compression test was alright..( dont rem exact numbers).. no metal in the oil. the entire motor cranks over and over.. the starter just spins te motor.., no combustion no kicking.. just smoothly turns over and over...
1995 240sx se
1992 240sx
1990 240sx se
1993 240sx sr20det
Old Aug 16, 2006 | 01:39 PM
JimmyHat's Avatar
Sphincter Say's What?
your positive you have fuel making it into the cylinders? are you injectors working? is the fuel pump kicking on and making the priming sound? Have you checked all the fuses/relay's under the hood? If you want a place you can post your tech questions and dont want to deal with all the TRama send me a PM and I will give you a link to a bay area forum where you wont find all the BS.
Old Aug 16, 2006 | 02:31 PM
yes it is getting fuel, and the fuel pump is working.. we pulled the hose and all that.. the only thing i can think of oquld be the injectors... but the car smells of gas after we try over and over again.. so the belief is that it is flooding.... is there ne way we can check the injectors to see if they are working..??.. what relays would cause the car to do this/??? we checked most of them..but i suppose there could be one we missed somewhere.
1995 240sx se
1992 240sx
1990 240sx se
1993 240sx sr20det
Old Aug 16, 2006 | 02:34 PM
djzstang1's Avatar
master driveway ninja
plugs have gas on them injectors are workin.
98 camaro SS
91 stang gt 5.8
05 zx6r 636 yup itz orange..
05 R6
street spin SR20 s13
project Dynaco40
90 s13 240sx
91 s13 240sx
92 s13 240sx
93 s13 240sx
95 s14 240sx
for your pasco 240/DJM parts
Old Aug 16, 2006 | 02:37 PM
JimmyHat's Avatar
have you been able to get the car to backfire?
