sr20det no start
start with the small stuff. usually when a charge pipe blows out the plugs foul. get new plugs and start from there. whoever told you it was the maf doesn't know what the symptoms are for a failed sensor. i'm almost positive it is your plugs unless something mechanical crapped out on you. good luck.
-ken
-ken
Many aftermarket EMS don't know "how" to throw a factory CEL. You have to hook it up to a reader and see what happened. I'd work backwards - check your fuses, plugs, ignition, hook up the EMS to a code reader, then look for mechanical problems. If you werent pushing hard enough to break something mechanical - its probably electrical :-p.
lol
