Mazworx S14 Dyno #'s...
http://www.inductionperformance.com/...s14drag997.wmv is this the car!
Matthew "RudeBoy" Nugent 2/03/88-04/01/09
Originally Posted by ihaterice
can we just call this 1000 whp ?
I assume that the block is sleeved.. What are you using for head studs? Did you machine the block out for 1/2" studs, or are you still on stock diameter?
Travis
www.fi-r.net
Nissan Performance
www.fi-r.net
Nissan Performance
damn......
Nissan North America - Canton
Nah.. there's at least 2 other S14's that are faster.. One in Aussie that's in the low 9's, and the JUN hyper lemon Silvia is in the 8's I believe..
www.fi-r.net
Nissan Performance
www.fi-r.net
Nissan Performance
Mazworx ran a 9.28, but I'm not sure how that stands up against the Aussie car. Jun's hyper drag S14 silvia did an 8.87 back in 1998, but only did it once with all other passes as low 9's.
*edit* The DEVLSH car from down under claim the world record at 8.766. You can see the movie on ex vi termini.
Mark's(Mazworx) car is on the cover of Modified this month. Check it out if you want a full spec list on the build up. No doubt this car will be going deep into the 8's.
Keep in mind that Mark has already run a 9.28 with not near the HP as now. He has been beat only by the red wrx in his class, easystreet i think? And that car is AWD and running an auto.
BTW, the car was just here at Bradenton making some test passes yesterday!
