not key, key troubles
Old Jun 15, 2006 | 10:27 AM
eastcoastchaos's Avatar
professional badass
Default not key, key troubles
does anyone know what i have to do to fix my ignition problem, my key falls out when i take sharp turns, can i just go i buy a new ignition or am i SOL
hector has SPUNK
yeah thats right SPUNK
Old Jun 15, 2006 | 10:34 AM
Projekt's Avatar
No
im sorry but i must make this comment before anyone else does....
it falls out of the ignition when you take a sharp turn? HAHAHAHAHAHAHAHAHAHAHAHAHAHAAAHHAHAHAHAHA
ok im done.... hopefully its not anythign major
Old Jun 15, 2006 | 01:27 PM
josht34237's Avatar
Revolutionary
It does hurt anything, why not just leave it if not you'll have to replace the ignition.
Old Jun 15, 2006 | 01:34 PM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
Make your own stubby screwdriver key.
jb weld the bitch in.
install alarm.
Old Jun 15, 2006 | 01:47 PM
ImportCorner's Avatar
drifting in a lot near u
i believe that the ignition is rivitted on the colum.
there is a little lever if you take the plastic off around it. where the key go's.
when you do that look at the key and right behind it is the little lever its got a red tip.
make sure thats not stuck in the middle or it will happen sometimes. My key got stuck in the ignition alot and that was the problem mabye same issue. just my 0.02.
Import Corner Inc.
www.importcornerinc.com
Your pasco jdm/aftermarket speacilist
Old Jun 15, 2006 | 04:04 PM
steve's Avatar
madpom
take your vin number to the dealership get new key
yours in worn out
Old Jun 15, 2006 | 05:32 PM
Epstein's Avatar
Retired
You'll need the VIN and the 4 digit secret code from the glove box. Hope you haven't lost it!
Old Jun 16, 2006 | 02:25 PM
tak's Avatar
tak
A to the K
My work truck does that, first time i was like WTF as the keychain hit the ground.
Find a junkyard car, and steal the doors, trunk, and ignition keysets...
the steering column bolts have nothing to grip onto, so you will have to hammer+chizel rotate them out, and then you can replace them with standard bolts (hex style fit better, because tool goes inside, and not outside, limited work area)
Old Jun 17, 2006 | 12:12 AM
Garage Battle's Avatar
i wanna go fast
does anyone know what i have to do to fix my ignition problem, my key falls out when i take sharp turnsL
stop taking sharp turns
Old Jun 19, 2006 | 02:48 AM
professional badass
yeah right
anyway, there is another problem with it. i can start my car with any objest that will fit in the ign.
hector has SPUNK
