blow off valve on side mount intercooler?
Old Mar 30, 2006 | 07:25 PM
I'm Phucked's Avatar
army pilot
^ compressor surge usually type s is a high pitched sigh noise you may have vacumm lines hooked up wrong or your bov is toast.
In a relationship you are either man or woman choose wisely [fortune cookie @ Ling's garden]
Originally Posted by Tackleberry
thats an insult to a circus
Old Mar 30, 2006 | 07:34 PM
Superkaioken's Avatar
no bov isnt hooked up yet its got the stock one..
Old Mar 30, 2006 | 11:57 PM
dan's Avatar
dan
Get the fuck off my lawn
the greddy valves also require tweaking with the adjustment screw on top so it isnt open at idle and holds boost without leaking. if its not hooked up, it will leak under boost (since there is no pressure in the line that would connect to it to help hold the diaphragm down). if it is hooked up and is still getting surge, back off the adjustment so it opens more (it was too tight), but make sure its not opening at idle.
technically on an engine using a MAFs setup, it should be recirculated. most stock turbo cars run on MAFs, and their bov's (my dsm one i have does it, so will the stock sr20 sidemount bov) are open at idle. with aftermarket ones, they are usually not open at idle with proper adjustment, and using an s-afc's deceleration function can help with keeping the idle from stalling out after clutching in, but many times, the richness between shifts will still happen, since the ECU is already dumping in X amount of fuel for the Y amount of air it metered, but the BOV lets some of that air escape causing a quick rich condition and a nice fireball or backfire or something. nothing to really worry about though if you can live with it. my car runs 50 times better recirculated, esp partial throttle runs passing traffic and such, and i believe i picked up maybe 1 or 2 mpg
Old Mar 31, 2006 | 05:23 AM
SilentKrnSoulJah's Avatar
(> '.')> V.I.P <('.' <)
changed mind im gonna wait for FMIC then get a bov
Old Mar 31, 2006 | 06:23 PM
JimmyHat's Avatar
Sphincter Say's What?
correct me if Im wrong but shouldent the stock BOV always be letting pressure out in the rev up?
