Speed Sensor
Old Mar 20, 2006 | 06:16 PM
custom240sx's Avatar
DC Crew Member #1
Default Speed Sensor
From what I have read the speed sensor on a 1990 240sx hatch is on the transmission. So if I put my auto tranny in drive and pull the car with my fourwheeler, would it register a speed on the gauge cluster and will it affect the odometer any? I need to know because I want to make sure everything is working in my car before I go much further on my work. Also, all I need is a battery hooked up with the positive and negative terminals correct?
Old Mar 21, 2006 | 06:30 PM
DC Crew Member #1
Old Mar 22, 2006 | 03:23 AM
innerflaw's Avatar
If you have to pull your car with a 4 wheeler to test the speed sensor it sounds like you have bigger issues. I would'nt worry about it because it's an easy thing to replace if it's bad.
89 240sx coupe
Old Mar 22, 2006 | 05:20 AM
Epstein's Avatar
Retired
the speed sensor should work as long as the key is in the ON position.
Old Mar 22, 2006 | 10:58 AM
coryishot19's Avatar
bored...
umm wtf?
