starter problem
Old Nov 16, 2005 | 08:34 AM
extremetrouble's Avatar
Default starter problem
have s 13 91 hatch it wont start it has done this a couple times in last few months the starter is hard wired to the ignition cause it was a auto to 5 spd swap one morning it will sound lik it is shot and isnt getting anough power but will still start then next time you go to start qill try and stop after it will just click is this just the starter or what please help!!!
thanks david
Old Nov 16, 2005 | 08:40 AM
osama tim laden's Avatar
kings cannot fall.
i dont understand why an auto to 5 speed swap would have the starter hardwired.
there is some other issue there.
Old Nov 16, 2005 | 09:20 AM
Epstein's Avatar
Retired
Paul Kersey,
Auto to 5-sp conversion needs the auto tranny lockout hardwired.
extreme,
Sounds like you have a bad/loose connection on the starter power wire somewhere. Check the positive cable that runs from the battery directly to the starter, the grounding strap that connects the engine to the chassis, and the strap that connects the battery to the chassis.
Old Nov 17, 2005 | 03:08 PM
CB7 Type R's Avatar
the Nemesis
Originally Posted by Epstein
Paul Kersey,
extreme,
Thanks for the help bro, points for you
In Europe Honda released the Accord with the H22 engine, they called it the Accord Type R!
