Wheel flushness thread! yes? no?
Originally Posted by ag04
I would think somewhere around a 17x8 +25, 17x7 +13, 17x9 +38 would be nearly perfectly flush with 0* camber on the front, but i am not certain since I haven't seen it...
I'm running 16x8+30 with a 225/50/16 and .4* of camber up front. The tabs on the fender are the only thing that that rubs. If you look straight down over the fender, you see roughly half of the side wall. I would call it very flush, but when I get it aligned and set to 2.5*, I'll probably get a spacer of some sort. The rear with the same wheels/tires is about 15-20mm underflushed, with 3.2* camber.
my wheels dont have offset
205 50 15 tucked in front 205 55 15 tucked in rear
kumho spt front kumho asx rear
camber as per required to rub 1 business card at all four corners
rest in peace tim.
rest in peace tim.
Don't remember my offest, but running Work 17x8 front w/ 17x9 rears
rockin' 215/45/17 Kuhmo 711's front
and then 235/45/17 Kuhmo 711's rear
Gonna need some flares after I correct the rear neg camber w/UCA's....
< < < < < PANDA FINGA!! > > > > >
needs to be lower than stock JP springs i know.
15x7's on all corners, figuring around a +20 all around
BFG G-Force Sports 205/55/15 all around
All setups have -2 camber all around
Setup 1:
Stock Body
17x8.5 +25
17x9.5 +30
MT DT05R
Setup 2:
needed to be lower
20mm front fenders, slightly pulled rear fenders
18x8.5 +25
18x9.5 +30 w/ 5mm spacer
Nismo LMGT4
Setup 3:
20mm front fenders, heavy pull on rear fenders
18x9 +16
18x10 +24 w/5mm spacer
SSR SP1
Not a good angle...sorry
Setup 1:
Stock Body
17x8.5 +25
17x9.5 +30
MT DT05R
Setup 2:
needed to be lower
18x8.5 +25
Nismo LMGT4
Setup 3:
18x9 +16
SSR SP1
Well its low enough now...hahaah. Scrape evertime pulling in and out of the shop.
Here are some better pictures of it now finally thanks to Mark. Think I need to go to a 10mm spacer in the rear or a little less camber. For some off reason I get this weird feeling a +10 offset would be perfect...hehe
