Clutch Fluid Leak
Old Sep 20, 2005 | 09:29 AM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
werd, I'm on it.
Buying/Selling on TR is like shaving your ass before going to prison. You know your gonna get fucked, you just try and make it as pleasant as possible.
Old Sep 20, 2005 | 05:30 PM
Illswyn's Avatar
I had my slave cylinder replaced.
Then the slave cylinder again. Then the master cylinder.
The slave cylinder is leaking...again.
I'm getting tired of this...I have to take it to the shop because I don't drive the car except to go to work, so the only time it gives me any trouble, is going to work, and have no time to do the work myself ):
I squeeze the boot at the slave cylinder, and black fluid comes out.
Old Sep 21, 2005 | 09:20 AM
Durdan's Avatar
No Ants Drift Member
DO NOT REBUILD IT!! just buy a new one. everywhere will want $50+ for it though. go to carquest. $37.00
RIP Tim. i miss you, buddy
Old Sep 21, 2005 | 09:49 AM
I'm Phucked's Avatar
army pilot
1/4" drive is the win for the clutch master on the firewall 12mm bolt. and the one behind the brake booster I found best to start it by hand (weird finger contorting method) and then tighten down by 1/4"drive. Just advice but going under a car for a 3,4,5th time to pick up 12mm nut is a sanity buster.
-Dave
In a relationship you are either man or woman choose wisely [fortune cookie @ Ling's garden]
Originally Posted by Tackleberry
thats an insult to a circus
Old Sep 21, 2005 | 07:56 PM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
-Dave
exactly the type of info i needed thanks.
And im buying a new m/c not rebuilding it, after i looked at it it seemed simple enough...
Old Sep 22, 2005 | 01:13 AM
Zapatista's Avatar
'89 Rattle Can Special
good luck call me sat and ill try to come by and help..... shareing is careing you know!
