S14 KA cooling problem
Old Sep 5, 2005 | 04:18 PM
  #21 (permalink)
osama tim laden's Avatar
kings cannot fall.
compression test wont always reveal headgasket problems though
Old Sep 5, 2005 | 06:07 PM
  #22 (permalink)
Jeff240sx's Avatar
Cpt. Negative
Originally Posted by dr. octogon
this post doesnt even make sense.
if the headgasket is blown, fix it.
while youre there, put in headstuds. unless you want to reuse the stock bolts.
i didnt realise we were under a parts conservation effort, and needed to so strictly ration parts.
Doesn't make sense? Do you know remedial math? $100 for stock headgasket and head bolts. $250 for a cometic headgasket and studs. Figure it out. $250 does not equal $100. And for a motor that isn't getting boost (it if is, I already said to disregard the post), stock is more than adequate replacement.
And the parts conservation quip was a joke. Apparently alot is lost on you.
-Jeff
** This space reserved for someone else's witty quote **
Old Sep 5, 2005 | 09:46 PM
  #23 (permalink)
RubberBerner's Avatar
Sideways Maffia
Leakdown test, and compression test will give you a good idea of whats going on inside, before you open it up. and just get a stock head gasket...no sens in spending all that money unless you're doing crazy boost.
NOBAMA!
Old Sep 6, 2005 | 06:25 AM
  #24 (permalink)
DrftDmn's Avatar
look ma , no hands!
Ok, Im getting a radiator pressure tester today, Im going to see if this thing spikes...To me if the radiator is getting compression from one of the cylinders It should be above what a radiator should normally see (correct me if Im wrong)
If so, Im not sure if I plan on going turbo...I had talked with dave about it, but its going t be my girls car and she has a lead foot already...and I dont want her dead.
so I think stock headgasket is the way to go....
Top speed is nothing .... Acceleration , now thats a thrill!
