S14 KA cooling problem
u took out the bolt on top of the intake manifold to bleed the air out of the system??? i had to do it about 4 times before all the air was out..i have had that exact same problem before..
Your problem sounds very similar to mine, except I think mine isn't to the point where yours is at.
For me, if i drive long distances I over heat.
What Taylor was explaining to me today is that I have a bad headgasket. Not to where oil and coolant are mixing.. but to where the motor is pushing air into the cooling system, causing mine to lose coolant (pushing a lot of air through, "boiling" over)
just take off the water pump and put on a new one... it takes 45 min.
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
Originally Posted by craig_302
if it's the headgasket. I say midaswell factor should come into play. (cometic HG and arp bolts)
edit: dave posting
edit: dave posting
-Jeff
** This space reserved for someone else's witty quote **
ok this is tampa racing. How many people have kept their 240 stock, very few or none. 2nd I was informed that this motor may see boost if it ever has a reliable future, but to each their own.
What if the upper hose on the radiator gets hot aong with the radiator but the lower hose stays cool? The radiator is not clogged either? Would it be a thermastat problem?
Sorry to thread jack but its on the same subject
Thanks
Thanks
Hello!
Hello!
Originally Posted by Jeff240sx
What the bloody-fuck for? $250 and $100 are very, very different prices... and unless the motor has boost in it's future, it's a total and complete waste of money, and good parts someone else could be using.
-Jeff
-Jeff
this post doesnt even make sense.
if the headgasket is blown, fix it.
while youre there, put in headstuds. unless you want to reuse the stock bolts.
i didnt realise we were under a parts conservation effort, and needed to so strictly ration parts.
+1 Dr. Octogon
Just have a compression test done and that should tell you if you have problems inside the motor.
[fortune cookie @ Ling's garden]
