SR overheating?
Old Jul 27, 2005 | 12:23 PM
poorboy44's Avatar
TR Balla Donor Supreme
ordered thermostat and a s14 coolant temp sensor. Will keep you posted on outcome
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
Old Jul 27, 2005 | 04:44 PM
Durdan's Avatar
No Ants Drift Member
how about ask the place that swpped it if they put the S14 KA temp sensor into your S13 motor. if not, it will read hot and get stupid when its not
RIP Tim. i miss you, buddy
Old Jul 27, 2005 | 06:19 PM
Kamikaze Takamashi 's Avatar
Tofu takeout
Get dual flexalite fans and that should solve it
Save 5 dollars when you preorder with promo code: TAKASC300
Old Jul 27, 2005 | 07:28 PM
poorboy44's Avatar
I did all the work myself so unless someone changed the temp sensor before i got the motor than its the sr sensor. Will the stock s14 temp sensor plug right in to my new harness? or will i have to get a plug off a ka harness?
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
Old Jul 27, 2005 | 07:40 PM
Durdan's Avatar
ok then thats your problem! its the SINGLE wire sensor (there are two water temp sensors) the red two wire plug is for the ecu. leave that one. the single wire one is for the gauge to read properly. remove the KA one and put it in the SR. the plug will plug right onto it.
