SR20DET shims (help)
Old Jun 22, 2005 | 01:22 PM
carlwill's Avatar
In the fetal position
Default SR20DET shims (help)
Guys, I threw some rocker arms out when I did the famous 3rd to 2nd gear shift.
Now I am missing 2 rocker arm shims for the motor...Does anyone have 2 spare rocker arm shims? The two shims I am missing are for one rocker arm & one side has a large groove and the other is smooth <see picture>. I will be in Tampa this weekend and will be at your house ASAP to pick it up!
Please let me know either via PM or Carloswillatgmaildotcom.
Linux System Engineer
Registered Linux User #391224
Old Jun 22, 2005 | 02:58 PM
Sr20phantom's Avatar
RacingInnovations.net
Did you mess anything up in the head? Did you bend any valves?
Old Jun 22, 2005 | 03:14 PM
DriftingDJ's Avatar
240LSX
pm me your number I will call you tomorrow I have plenty of shim test subjects for my clearance modification on them for solid lifters... rocker arm stoppers might be a good investment too while the valve cover is off.
Old Jun 22, 2005 | 03:32 PM
carlwill's Avatar
I sent you a PM and purchased Greddy RAS last week.
Does anyone know if there is a way to reseat the "rocker arm" with out remove the cam shaft?
Old Jun 23, 2005 | 10:37 AM
carlwill's Avatar
Have not heard back from you...
Old Jun 24, 2005 | 02:40 PM
Only if the cam lobe isnt pressing on it then should right off no prob.
Old Jun 24, 2005 | 06:38 PM
DriftingDJ's Avatar
240LSX
I got spare shims leftover from today I pmed you my number... you might be able to reseat a rockerarm that isnt pressed up against the cam lobe but you might have to remove the cams anyways. push down on your rockerarm where it meets the lifter. Is it sqishy? Anyways you still have to loosen and pull of the racks that hold the cams in to do the stoppers. but check those lifters you probably have some bad ones where you floated the rockerarms make sure they squish.
Old Jun 25, 2005 | 06:59 AM
Durdan's Avatar
No Ants Drift Member
theyre in your oil pan. trust me. just drop the lower balck steel pan and then remove the windage tray. theyll be in there.
RIP Tim. i miss you, buddy
