Need help on Oncecam
Old Jun 7, 2005 | 06:20 PM
asia989's Avatar
Why So Serious?
Default Need help on Oncecam
welp ive finally had it, car wont star i jus turn the key and nothing happens, i know my injectors are almost dead but would one wire broken off of the TPS have anything to do with it
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Jun 8, 2005 | 06:04 PM
asia989's Avatar
Why So Serious?
anyone?
Old Jun 8, 2005 | 06:12 PM
RubberBerner's Avatar
Sideways Maffia
TPS is a major sensor...i know OBD II needs it for start up...I believe OBD I needs it as well...it needs to know the throttle position to know how much fuel to dump in.
NOBAMA!
Old Jun 8, 2005 | 06:14 PM
Sideways Maffia
i believe it needs crank or cam angle sensor, tps, and map/maf
NOBAMA!
Old Jun 8, 2005 | 06:30 PM
asia989's Avatar
Why So Serious?
well then can anyone wire?
Old Jun 9, 2005 | 01:26 AM
40ozCasualty's Avatar
shift_lock
Is the car cranking at all? If its not check the remote wire on the starter, disconnect it, and jump it from the starter to the positive terminal on the battery.
If its crankng, Check fuel by pulling the fuel line off the fuel rail, and turn the ignition on and check for fuel, If you have that, check your spark plugs for any gas, or as I was told today use a screwdriver on the injector to listen for the clicking.
If you have fuel check for spark, I usually put a phillips screwdriver in a plug wire, and set it near a bolt on the chassis, and check to see if a spark is jumping the gap.
And i'm pretty sure you have air getting in the motor, so that can be ruled out.
I know the car will start without a MAF sensor, and I'm pretty sure it will start without a TPS sensor. It won't start with out the crank angle sensor though. Not sure about the map sensor.
Old Jun 9, 2005 | 02:29 PM
asia989's Avatar
Why So Serious?
its a odb1 the very first they came out with its like rubber said it doesnt know how much fuel to dump in. So if any of you know how to wire hit me up services will be paid for.
Old Jun 9, 2005 | 03:37 PM
AnTman86T's Avatar
S130 love
I am pretty sure your solenoid on the starter went out.. or your starter is dead. I would say take the old one off and take it to discount for the core and buy a new one which comes with the solenoid and usually has warranty. BTW most cares can run without the tps sensor, it will just usually cause the car to run a little richer.
Old Jun 9, 2005 | 03:45 PM
osama tim laden's Avatar
kings cannot fall.
it would help if you posted what processes of elimination, if any you have done to try to figure this out.
is it getting spark
is it getting fuel
does it have proper fuel pressure
are the injectors firing
and is the timing right.
Old Jun 10, 2005 | 01:39 AM
asia989's Avatar
Why So Serious?
is it getting spark
is it getting fuel
all of the above is correct
