sohc to dohc swap trouble
Old May 8, 2005 | 02:10 PM
knives's Avatar
TR Balla Donor Supreme
Default sohc to dohc swap trouble
Ok I'm going to try and explain this the best I can. 90 240 with a 95 ka and a s14/s13 converted harness done by Taylor. I just swaped it for my sohc and it ran fine for a day or two and now it won't start, I turn the key on and the egi relay starts buzzing, the starter just clicks then ignition control fuse blows. It's obvisuly a short , but where can it be and what is the egi? Thanks for any help
TR's resident A&P mechanic
I make a passive income from the comfort of my home, visit my blog, I would love to show you how to do the same
ISE Automotive-Mobile Mechanic and 24-7 Roadside assistance services from oil changes to full track car builds we do it all and get it done right the first time
Old May 8, 2005 | 02:18 PM
Durdan's Avatar
No Ants Drift Member
HAHAHA welcome to owning an 89-90 240SX!! the pair of egi relays involve the fuel pump. from past experience, i'd say your fuel pump is locked up and hsorting out the system. ask mattback about that one when he rushed me over one from clearwater brandon over 2yrs ago! HAHAHAHA
RIP Tim. i miss you, buddy
Old May 8, 2005 | 02:25 PM
knives's Avatar
wow I never would have guessed that. Thanks Taylor
Old May 8, 2005 | 04:40 PM
osama tim laden's Avatar
kings cannot fall.
haha, glad you finally got rid of that single cam pile.
Old May 8, 2005 | 07:44 PM
knives's Avatar
Well I replaced the fuel pump and got a new z32 filter. It's accually turning over now but it still won't start and the egi relay is still buzzing. ???????
Old May 9, 2005 | 06:15 AM
Epstein's Avatar
Retired
Running for a few days.... sounds like a dead battery due to the charging system. First make sure that you hooked up the alternator correctly in the swap. Then check the alternator fuse. If you're sure that the connections are all good, then your alternator may have crapped on you. Try jumping the car, then measuring the battery voltage. A healthy, alternator driven system should come in around 13.5V or greater. If you're getting around 11.X, then your alternator isn't charging.
Old May 9, 2005 | 08:01 AM
knives's Avatar
It's a new alternator but, its from my once cam since im using my 90 lower harness I figured it wouldn't matter. Could that be the problem??
Old May 10, 2005 | 08:11 AM
knives's Avatar
bump still having trouble
Old May 10, 2005 | 10:06 AM
forceFEDs13's Avatar
SUPAFLY!!!
hey man its miles.....ill be over later today to help u out if u want.....just let me know.....peace man
BANZAI
ADHD= Always Drifting Hardly Driving
Old May 10, 2005 | 01:06 PM
knives's Avatar
That would be cool, thanks
does anybody else have any ideas as to what it could be??
