sputtering/bucking
Old Apr 13, 2005 | 10:55 PM
storey's Avatar
Default sputtering/bucking
i know this is really hard to diagnose over the internet but here it goes:
car starts and idles fine but while driving at a constant speed the car will intermettenly start sputtering/bucking. when this happens my apexi turbo timer A/F reading will go from 14.7 to 20 then off the scale. however, when this happens if i give it alot throttle(3/4 or more) the A/F ratio will drop back down to normal and all sputtering will be gone. then after crusing for a little while it will do it again. i have allready replaced the tps with a new one an that did not help. the car pulls hard and runs well on boost. the problem is only during constant speed driving.
any ideas would be great.
list of mods:
s13 redtop
t3to4e
full race exaust mani
greddy type S blow off valve
greedy down pipe
apexi n1 exaust(single 3inch)
300zx maf
wolbro 255lph fuel pump
300zx fuel filter
740cc injectors
koyo radiator
fal twin cooling fans
blits LM intercooler
lightweight flywheel
spec stage 3 clutch(6 puck)
b&m shifter
apexi turbo timer
greddy profac b boost controler
various gauges
eibach springs
kyb agx shocks
apexi strut tower brace
j30 diff
motegi 16x7 wheels
adjustable fuel pressure regulator
tial 40mm waste gate
greddy pulleys(i thought they were underdrive)
megan racing streets (that sit to high even with the sliders removed)
greddy oil pan
arp head studs
greddy metal head gasket
nismo engine and trans mounts
apexi 300zx air filter
rom tuning
thank you for your help. this is beyond my skill level.
aaron
Old Apr 13, 2005 | 11:05 PM
craig_302's Avatar
boostmonkey
O2 sensor? Sounds alot like what mine went through when the wires severed themselves. Used that as an excuse to get a stainless elbow and 300zx style o2. Try inspecting the wires going to said o2 sensor. I ended up unplugging mine as a diagnostic "tool" to see if it made any difference in drivability since under WOT, it basically ignores the o2 sensor anyway if I remember correctly.
Old Apr 13, 2005 | 11:17 PM
storey's Avatar
im sorry i forgot to mention i did replace th O2 sensor(91ser sensor) with no change but i will try unpluging it and driving around to see what it does.
Old Apr 14, 2005 | 12:28 PM
cyanide's Avatar
i know you replaced the TPS, but did you check the voltage you are getting with the key on and WOT? did you adjust it within the proper specs?
Old Apr 14, 2005 | 01:15 PM
storey's Avatar
i followed the fsm directions(EC-204). where it says adjust the voltage between .35 to .65 volts i set it at .40v.
aaron
