oil leak....
Old Jan 3, 2005 | 07:08 PM
forceFEDs13's Avatar
SUPAFLY!!!
Default oil leak....
well after beating my 237g mile engine to hell the front main seal blew out and dumped all my oil all over the place....well i replaced that and now its comming from somewhere else.....does ne one kno any common leaky spots on the KA24? and where to get a decent priced aluminum radiator....or atleast one thats not plastic and leaks?
Old Jan 3, 2005 | 09:48 PM
dan's Avatar
dan
Get the fuck off my lawn
could be the rear main seal. if so, its a pain to change, gotta pulle the tranny, clutch, the seal is behind the flywheel, but its worth it to change it if you ever do a flywheel and clutch upgrade.
also check the valve cover gasket, that one sometimes gets old and brittle too. other than that there isnt too many leaky things on the KA.
Old Jan 4, 2005 | 01:59 AM
taka86fc's Avatar
Turbo>NA
You should go to car wash at night and clean the enginebay. Don't forget to keep the engine running while washing.
1998 J-Spec Z28 convertible (daily driver)
1991 240sx (U.S drift beater)
1990 SILVIA (JP drift beater) SOLD
1990 R32 Skyline (RB25 powered )GONE
1987 Toyota Corolla GTS (NEVER DIE)
anti-oval drift association
Old Jan 4, 2005 | 07:29 AM
RubberBerner's Avatar
Sideways Maffia
How old is your Oil pan gasket? thats probably seeping some goodness if it old. Could also be the rear main seal, but you could tell because there would be a nasty pile of oil right where the bottom of the tranny meets the block.
NOBAMA!
Old Jan 4, 2005 | 01:33 PM
dan's Avatar
dan
KA's dont use oil pan gaskets, just RTV/hondabond/elmer's
Old Jan 4, 2005 | 01:44 PM
Epstein's Avatar
Retired
My 93 coupe came with an OEM replacement radiator with brass end caps. I'd do a little search for one of those.
Old Jan 6, 2005 | 08:36 AM
SUPAFLY!!!
brass end caps?
BANZAI
ADHD= Always Drifting Hardly Driving
Old Jan 6, 2005 | 09:07 AM
Epstein's Avatar
Retired
looks like stock, but instead of plastic, it's brass with black paint. Could be copper. I'm not a metalurgist.
Old Jan 7, 2005 | 08:34 AM
SUPAFLY!!!
oh i got ya lol
BANZAI
