Who's ready for the 6sp KA24DE/SR20DET?
Well, it looks like the folks down in miami (BYP) did it to a couple of their cars.
600+ whp.
check this thing out:
yeah so byp pretty much shut everybody up!!
I have a 2004 Infiniti G35 6SP transmission BRAND NEW 0009 MILES ON IT-- for sale (proven to work with SR/KA with adapter plate )
$400 obo.
600+ whp.
$400 obo.
rest in peace tim.
rest in peace tim.
details? $400 for the whole Tranny? How is the gearing for drifting? how much is the adapter plate? everything else lines up?
Charles
Charles
My Blog: www.HotRodCaddy.com
Adaptor plate needs to be custom. Seems that with an adaptor plate the input shaft would need to be a bit longer, but I'm unsure of that. The tranny itself is massive, so some tranny-tunnel customization might need to happen (aka - Big hammer to little tunnel).
However, Matt, if you'd like to help with the fabrication, I'll buy it and pay you.
-Jeff
-Jeff
** This space reserved for someone else's witty quote **
Details are this. you remove the metal plate that goes in between the motor trans
you weld a plate on with the correct bolt holes that is 1/4" thick out of aluminum. now the trans bolts to it. you make sure you use all the bolts and tht all the welds are strong. then you're in business.
throwout bearing depends on which clutch you use, you may have to drill some holes in your flywheel to use the 350z clutch, or use a custom throwout bearing off of a pulsar ( most commonly used) and use the sr clutch. or a twin plate.
the gear ratios are closer and shorter than the 5sp that the 240sx / silvia has. 6th gear in this trans is equal to 5th gear in the 240sx. that means 1-5 is MUCH closer and shorter, plenty of gear selection for drifting.
rest in peace tim.
rest in peace tim.
Halo, I picked it up from a friend.
It's 100% legit, let me see if i have a pic or two
they are on Regina's PC, i don't have access to the pics righ tnow, you're welcome to come to oldsmar and see it for yourself.
rest in peace tim.
rest in peace tim.
First:3.794
2nd: 2.324
3rd: 1.624
4th: 1.271
5th: 1.000
6th: 0.794
1st: 3.321
2nd: 1.902
3rd: 1.308
4th: 1.000
5th: .838
Oh ya.. drifting setup.
-Jeff
2nd: 2.324
3rd: 1.624
4th: 1.271
5th: 1.000
6th: 0.794
1st: 3.321
2nd: 1.902
3rd: 1.308
4th: 1.000
5th: .838
-Jeff
Meh... I grabbed the info from www.200sx.org for their S13/S14 gear ratios. Maybe they are listing the CA as an SR for some reason.
-Jeff
-Jeff
(hoping you/someone does)
