sr20det over heating?
Old Nov 20, 2004 | 11:08 AM
DriftingDJ's Avatar
240LSX
Default sr20det over heating?
ok the motor runs perfect can ride around all day in stop and go traffic but prolonged driving causes the motor to over heat like after about an hour of steady 3000 rpm driving on the highway doing 65 the motor heats up and I have to stop but I dont have to turn it off in idle it cools down. this is mysterious to me can anyone give me an idea before taking it in?
Old Nov 20, 2004 | 11:46 AM
RubberBerner's Avatar
Sideways Maffia
no thermostat? that will do it...bad radiator cap will do it too...obviously you're fans are working, because in stop and go traffic when you're stopped its cooling it down, therefore NOT overheating. Had this on my KA... its probably one of the two.
NOBAMA!
Old Nov 20, 2004 | 01:42 PM
DriftingDJ's Avatar
240LSX
thanks man I will try the cap thermostat is there
Old Nov 26, 2004 | 10:27 AM
zeetard's Avatar
Default cooling
If the coolant dosen't spend enough time in the radiator, it can't get rid of it's heat. The thermostat slows down the flow quite a bit. The cooling system was designed by some clever peeps.
Also the engine has to heat up quickly to start burning off water that is a by-product of combustion. You will get sludge build-up if you run too cool all the time.
Old Nov 30, 2004 | 11:02 AM
creophus's Avatar
'Bout it 'Bout it
Default bubbles?
Are you getting any bubbling from the overflow tank when you shut the car off? If so you have air trapped in your cooling system. Have you changed your coolant lately? radiator? hoses? This was my problem. Whatever it is...get it taken care of...don't loose a $3000 SR install over a <$300 radiator, fan setup.
Old Nov 30, 2004 | 11:47 AM
Enthalpy's Avatar
TR Balla Donor Supreme
i used to have the exact same problem. turned out to be a shitty stock replacement KA radiator.
Old Nov 30, 2004 | 12:49 PM
DriftingDJ's Avatar
240LSX
ok thermostat gone new koyo radiator and cap lines all good no leaking but water still boiling ordered a s14 water pump to replace the old so that should pretty much be everything thanks for the tips
Old Nov 30, 2004 | 04:16 PM
Slash's Avatar
THE HAMMER
hey Drifting DJ? thats my old HICAS right? sweet to see u have it running w/SR.
I dont feel like a sig today.
Old Dec 1, 2004 | 03:29 AM
vanliktenstein's Avatar
Default overheating
hey i had the same problem to the t i have ka thow but my problem was the actual temp sending unit it had a little corosion build up and it would read right at all if i were u get a heat gun go drive ur car and then use the gun on the hoses and all over the radiator if the hot hose is about 200 or 190 and the cold side is 160 or so ur fine i did the same thing changed cap waterpump thermostat hoses flushed the antifreeze a million times it beat me up for about 2 weeks now if u have straight antifreeze u will overheat also i do a 60 per water and 40 antifreeze water disipates heat better
