The First S31 Sr20 With A 300z Transmission
Originally posted by silviadriftr
Enjuku's tranny in their red drag car has an os giken upgraded trans in it, but the kit is 2900 plus you still have to get the parts installed and the trans taken out and put back in. Their back up car is the one I talked to Ray about, which does not have the upgraded trans but they have a clutch that has a controlled slip or the driver can slip, but he said their transmissions in that car only last a couple of races and then they have to rebuild or get a rebuilt one.
A slipping clutch is not a luxury for me since I'm running the twin plate exedy stage 4 with no slip at all and good to 750 rwhp. I started breaking transmissions right after the upgaded turbo, turbo manifold, intercooler, injectors, ecu, ect. The motor was putting down 397rwhp and 342 ft lbs trq on all stock internals, no port and polish, never taken the oil pan or the head off the car since I have gotten it a year ago.
rest in peace tim.
rest in peace tim.
That's what I was told three month's ago when I talked to, I thought it was Ray, but I have also talked to Jason and one other guy. Sorry about the mistake but thanks for being so polite in correcting me. And your not the only guys I've talked to about the transmission situation that everyone is running into with high horsepower cars so didn't mean to relay bad information but thanks for the verbal abuse.:bbb:
Oh and by the way, most cars having these problems are cars running slicks,et streets and drag radials for drag cars not drift cars. For example batlgrounds car puts down 440rwhp and has had no trans problems because it's not the horsepower that kills them quickly, it's the harsh engagement of launching at a high rpm and no spinning. I don't think your drift car hooks enough to do that unless you can pull 1.5 to 1.6 60ft times, in that case you may need a transd upgrade.
Mainstream Performance
Home of Turbo Dave Fabrications
2JZ TDF Built 240SX
My RHD TDF Built SR20
record holding-473whp sr20
stock cams and bottom end
2JZ TDF Built 240SX
Originally posted by Ostrich
I have a 2004 G35 Six speed transmission with 9 miles on it. I am interested in getting this modification done, do you need it for test fitting??? (Not for me, for a friend's car)
2JZ TDF Built 240SX
2JZ TDF Built 240SX
I have this 6 speed just sitting here, it's brand new. I would love to put it into a 240SX, but if you want it, you can have it for pretty cheap. Maybe a nice street car KA or something. I have the driveshaft for it as well.
Regardless, I agree with you that it is the driveline shock that kills the transmissions. 90% of the time you end up snapping the output shaft ona hard launch. Derek Greaser with a fully stripped coupe and 350whp ran a 10.9 in his car witha 1.44 60' time. He stressed that you had to be as gentle as possible getting it out of the hole though, and if you listen to it, it is. He's about the best 240sx driver I've ever met, and even driving ont he street he is very smooth about it. He uses high rpms and alot of slip to get it out of the hole, and it works. He's never broken a transmission in his old drag car, for the record.
rest in peace tim.
rest in peace tim.
360+whp/tp+
Slicks
No slip clutch of choice
Hard Lauching=
Toasted Tranny:bbb:
Hey man, I wasn't trying to attack you! I was just like, holy shit, do we !??! I had to call up Ray just to make sure! Maybe you talked to Jason, and I know at one point that a giken gearbox was on the agenda, but we never got aroudn to it. I'm sorry if I came off the wrong way.
Also sorry about the misunderstanding , no problem.
2JZ TDF Built 240SX
2JZ TDF Built 240SX
How long dd it take you to cut the aluminum plate, drill holes, line it up and weld it all? I know scott and adam are both VERY interested in it, i may know two more as well!!
rest in peace tim.
rest in peace tim.
Originally posted by Ralph
I was going to ask you if the amount of transmissions breaking was due to slicks. That does seem to be the case in most of the SR tranny problems I've been coming across
360+whp/tp+
Slicks
Hard Lauching=
Toasted Tranny:bbb:
360+whp/tp+
Slicks
Hard Lauching=
Toasted Tranny:bbb:
2JZ TDF Built 240SX
2JZ TDF Built 240SX
2JZ TDF Built 240SX
2JZ TDF Built 240SX
All of the cars already have aluminum driveshafts in them
How thick of aluminum plate did you use ? Because you used the aluminum plate, I ASSume that you removed the cadmium plated steel backing plate that goes between the engine block and the transmission (You know the one I always forget to install before putting the flywheel and clutch on, hahaha) This way you don't have quite as much thickness as you normally would.. Is that the case?
rest in peace tim.
rest in peace tim.
