The First S31 Sr20 With A 300z Transmission
Old Nov 12, 2004 | 11:04 PM
craig_302's Avatar
boostmonkey
Nice work!
Wish 6 speeds were cheaper, it would be nice to have for the highway.
Old Nov 13, 2004 | 05:24 AM
silviadriftr's Avatar
"THAT AIN'T RIGHT"V8 OWNR
Originally posted by craig_302
Nice work!
We looked at doing the t-56 but decided against it due to gearing differences and tunnel modification. The advantage of the 300z trans, if done correctly is that it fits in with no modification to the tunnel. Also, if done correctly, you can use the factory starter, slave cylinder, clutch, flywheel, throw out bearing and fork. With any of the 6 speed most of the parts have to be different and the adjustment on the clutch woill adjust far enough to accomodate the spacer being used to change the bolt pattern. Oh, also the 300z trans fits into the car better than the stock bellhousing. Trust me on that,I've swapped the transmission out in mine numerous times. After some test runs Dave -owner of www.turbodave.com is looking at selling the upgrade and doing all fabrication in house for the setup, but that will be determined after testing this weekend.
As for the hwy, the 89-94 sr/ka trans works pretty well for that because the gears are longer and lets just say, I don't hesitate to run vets or vipers on top end
Mainstream Performance
Home of Turbo Dave Fabrications
2JZ TDF Built 240SX
My RHD TDF Built SR20
record holding-473whp sr20
stock cams and bottom end
Old Nov 13, 2004 | 05:41 AM
Matt Vassallo's Avatar
lifelong learner
I wonder how a Z33 6speed would do? The dimensions are similar to that of a Z32 transmission. (Reason I ask is I have a 6 speed at my house that's doing nothing. )
rest in peace tim.
Old Nov 13, 2004 | 06:00 AM
The 6 speed from the z33 is weaker than the 300z. The 300z holds around 850-950 rwhp where the 350z hold around 650rwhp which would be enough for now for me but not after I build the motor over the winter.
2JZ TDF Built 240SX
Old Nov 13, 2004 | 06:01 AM
HaloZ's Avatar
highway whore
prolly wouldn't last as long as the KA/SR tranny.
glad i have an extra TT tranny in my garage in case my SR one craps out, along with lighten fly and HD clutch. i woundn't htink twice about tossing that in there is this kit works out.
the starter is so easy to get to vrs the SR/ka it isn't funny.
of course a custom DS would be needed sense the Z's out put shaft is larger.
i wonder what the odds are that a NA drive shaft would fit.
Old Nov 13, 2004 | 06:44 AM
The na drive shaft won't fit. That's one thing that has to be made. The advantage of having to do a drive shaft is you can make it a one peice, which is what I did. You don't have to do a special drive shaft just a one piece drive which is stronger than the two piece. As for the starter we retained the sr starter and just built the adaptor plate to accomodate.
I think the ka/sr is rated up to 350 without a slipping clutch. With a slipping clutch I know enjuku is running theirs on stock transmisssions with their 2nd car(not the red one) and are going through transmissions. The 350z trans should hold 600-650 rwhp without a slipping clutch. I just wanted over kill with the 300z trans holding 850-950 rwhp.
2JZ TDF Built 240SX
Old Nov 13, 2004 | 08:43 AM
  #17 (permalink)
HaloZ's Avatar
highway whore
well my old room mate's GF 350 has had the 6 sp replaced twice, and it wasn't cuz she dosen't know how to drive, the 6's in the z33/v35 are not that strong.
Old Nov 13, 2004 | 12:24 PM
  #18 (permalink)
Rob.M's Avatar
Down Shift Magazine
Default Agreed
There have been some well documented issues with the 350Z's 6 speed manual transmission. Sad, since I so wanted to pickup a G35/350Z.
Old Nov 13, 2004 | 02:23 PM
  #19 (permalink)
HaloZ's Avatar
highway whore
i heard the 05's where suppose to have the issue fixed... but who knows. =\
Old Nov 13, 2004 | 03:19 PM
  #20 (permalink)
craig_302's Avatar
boostmonkey
I know the t56 is a pretty bulky tranny from my ford experiances. Who is the 350Z tranny made by (if not by Tremec than who in otherwords). I'm never going to push enough HP to break it, I just don't like spinning 3k @ decent cruising speeds or going through the sacrifice of putting in a taller rear gear which doesn't even exist unless custom made.
