after rebuild, 240 still runs like crap
Old Nov 8, 2004 | 04:28 PM
osama tim laden's Avatar
kings cannot fall.
Originally posted by knives
I will try the temp sensor, i don't have the funds to swap a motor, unless we could start a get this kid a new motor fund, btw what would i need to swap a dual cam motor, harness, ecu, throttle cable, move p/s lines, and the motor, anything else??
yes, harness, ecu, cable, BUY NEW AC AND P/S LINES, and motor... oh, also, i switched evaporators, and condensors.
Old Nov 8, 2004 | 05:08 PM
knives's Avatar
TR Balla Donor Supreme
Thanks, oh and another question, Where is the engine temp sensor??
TR's resident A&P mechanic
I make a passive income from the comfort of my home, visit my blog, I would love to show you how to do the same
ISE Automotive-Mobile Mechanic and 24-7 Roadside assistance services from oil changes to full track car builds we do it all and get it done right the first time
Old Nov 8, 2004 | 05:45 PM
Ralph's Avatar
IF you dont have a FSM goto www.zeroyon.com and dl one which should give you a general idea of what/where you are looking for. Not sure for your make/model but its usually right near/next to the tb having 1 or 2 wires coming from it.
Also...try google and/or some of the other Nissan Boards for more info.
TR Profile
Myspace Profile
Old Nov 8, 2004 | 05:49 PM
kings cannot fall.
its on the front of the intake manifold. should be red plastic with a hex nut under that.. and one wire going to it.
make sure the car is cold when you replce it.. or hot coolant will most likely spray on you.
replace it, and make sure all the cpins are tight on the harness, and clean them with dielectric cleaner if there is corrosion.
and it will still run so-so.
Old Nov 8, 2004 | 08:18 PM
Slash's Avatar
THE HAMMER
LOL my singlecam will never die! (or act stupid) LOL.
well so far it hasnt, hopefully it keeps up the good fight
I dont feel like a sig today.
Old Nov 10, 2004 | 12:21 AM
knives's Avatar
well I tryed the sensor and it didn't help one bit, I ran of of all ideas, so I think I will suck it up and swap a dual cam if i can't find this problem. does anybody have a complete dual cam just lying around, harness, ecu, or anything I will need to swap? I've got cash or paypal.
Old Nov 10, 2004 | 03:26 AM
  #17 (permalink)
lillzilla's Avatar
Fallen from grace~
call XAT for the DOHC motor and swap parts ......813-875-7223
the SOHC 's problem is probaly some lil stupid ass wire or MAF causing all the problems . you mentioned changing the maf and coil but were they used parts ? disributor pos ?
get a DOHC, with all the SR'S running around
i know they're is plenty.
don't tell your mom you seen me !!!!
Old Nov 10, 2004 | 09:05 AM
  #18 (permalink)
knives's Avatar
The maf was used but the coil was new. My dizzy could be shot, I'll give XAT a call.
