Smoking
Stock CA w/ stock turbo. Around 4-5k (after spooled) it starts to smoke out the exhaust.....kinda alot. I originally had too much oil in there, but drained and re-set the level since. Any ideas??
< < < < < PANDA FINGA!! > > > > >
umm ok, it looks like the whole back end is on fire......but when I ease off - it thins out to nothing.
Do exhausts make that much smoke??
no that sounds like a turbo problem ..or could be your maf check that to..on my ka my maf clip came off and i was shootin black smoke from hell, but couldnt go past 3k in any gear
jason
jason
Don't Text And Drive
Oil burning, (Greyish) Coolant = Blueish grey, and running rich = black. Do you have any idea what it is burning besides "White?" Usually if it is the turbo seals it would be blowing oil on any boost and when it's shot at idle. Try to solve and eliminate some of the possibilities.
LIke i said, only under load w/ turbo spooled. doesnt happen unless i lean on it. The smoke could be greyish-white, but its kinda hard to tell at 60mph. I'm guessing that if its oil=turbo seals. after all ...stock CA turbo=about 14 years old and 154,000Km.
