Walbro fuel pump install notes.
Old Oct 20, 2004 | 05:26 AM
  #21 (permalink)
Rob.M's Avatar
Down Shift Magazine
Default Suxor
I can only imagine what she had to say, as if you were not having a shitty enough evening to begin with. Sorry man.
Old Oct 20, 2004 | 07:51 AM
  #22 (permalink)
Jordan Y.'s Avatar
15 seconds EXHILARATION
This thread has motivated me to put an OEM sock on my Walbro. I have had less ability to run the tank down since swapping that Walbro sock in there.
Originally posted by Clifford
mine came with instructions.....pretty easy hehe
seemed easy to me...only place I encountered was the fuel lever assembly...the fuel level "reader" i guess kind of went dry and no longer worked so we did a couple tricks with some sandpaper and back to normal....(it caused the gas gauge to not read anything)
What did you do? Mine did the same thing, I had the assembly out of the tank for a while and even though I took care to handle the assembly gently because the VFAQ mentioned possibly breaking the fuel gauge sender, when I put it back in the gauge didn't work. Not that I have missed the gas gauge for the year and a half since then.
Old Oct 21, 2004 | 04:22 AM
  #23 (permalink)
TNathe's Avatar
Originally posted by John
how do you get sparks when you are tapping metal to plastic?
Do these gas tanks require an airtight seal to work properly? Just curious.
Old Oct 21, 2004 | 04:42 AM
  #25 (permalink)
TNathe's Avatar
Cool, thanks man. I was asking 'cause I was unable to get the cap to seat tightly against the plate w/ the fuel lines and stuff. It's just a hair too loose and hitting it w/ a screw driver manages to ream off the knurled edges so I don;t wann do that.
Reason I was wondering is because my car still stutters when not under boost and I am just grasping at straws. I'm to the point to taking it to a shop and paying someone to go over the whole thing to figure it out.
