Question about SUBS in my 90 Z32
Old Oct 18, 2004 | 11:43 AM
  #21 (permalink)
TNathe's Avatar
Drill a .5" diameter hole on the firewall next to driver side fender. There're other ways to wire battery cables, but I think this is the easiest. Connect 2 power cables to positive
The concept here is pretty straightforward, If there are no grommets in the firewall that are easily accessible then one must take matter into their (i'm hoping someone elses in your case) own hands and drill a hole.
Edit: How do these tools end up with "supercars" and don't know reading comprehension?
Old Oct 18, 2004 | 11:51 AM
  #22 (permalink)
The Moneyshot's Avatar
Watch out for the $ shot!
#1.....I read and understood the preceding comments clearly. #2.....if ur posting this because you think I cant read your terribly mistaken.
#3.....I posted the question so that I could find the BEST spot to drill the hole if I had to, or if there was another way to run the wire. In no way was I ever denying the fact that the concept of drilling the hole was not straightforward.
Please, if your going to post a flame, take the time to read the posts before hand and know what your talking about when you do it.
FOR SALE! TWO 12" JL Audio W3's in a JL Box and a Kenwood 800w Amp. GO HERE for more info! https://www.tamparacing.com/forums/showthread.php?s=&threadid=185344
Old Oct 18, 2004 | 12:06 PM
  #23 (permalink)
TNathe's Avatar
OK, here's a more detailed description of the hole drilling procedure. As it says, drivers side of the firewall close to the fender, therefore, find a spot in that general location that you can drill a hole without the following happening as a result:
1) Drilling through important components like electrical wires, steering column, carpet, etc.
2) Having the wire be visible after it is run through the firewall (hence the hole was drilled too low)
Edit: I'm not flaming, well maybe a little, but people need to excercise some common sense sometimes and think about what it is they are trying to do and just do it. It ought not take 2 pages of responses to get a battery cable inside the cabin.
Old Oct 18, 2004 | 01:21 PM
  #24 (permalink)
osama tim laden's Avatar
kings cannot fall.
instead of driling a hole, which may be too advanced for you, just run the wire from the battery, out of the cowl area, tape it to the roof, and run it into the trunk.
that way you know you didnt drill the hole in the wrong place.
Old Oct 18, 2004 | 03:11 PM
  #25 (permalink)
jk240sx's Avatar
coast to coast
get or find an FSM or net FSM, your best friend. in 240 community we have a site with all info avavailable. the net is you friend. Google is your bitch. own her. Yo adrian ! post up!
jerry/
Old Oct 18, 2004 | 03:22 PM
  #26 (permalink)
sil8ty's Avatar
The Hebrew Hammer
Wow, this is much more thread than needed for a 1/2" hole and a $0.15 rubber grommet.
< < < < < PANDA FINGA!! > > > > >
Old Oct 18, 2004 | 03:29 PM
  #27 (permalink)
HaloZ's Avatar
highway whore
thanks matt, that's a big complament comeing from you.
personsonally, I HATE running power cable over the motor. so i ran mine down the hole next to the batt, and pulled back the pass side back wheel shroud, pulled back the carpet, and used a wire hanger from the cabin, through the frame rail, up to the inner fender/wheel well area and taped the cable to it and pulled it in there. but i hate drilling hole and i like it as clean as i can make it. but i doubt if this guy can do that.. so F it.
i just did almost the same thing to the 240 yesterday when i mounted the batt in the trunk, except it was through the gromit in the wheel well.
guess im a fish giver too now. someone shoot me..
odds are he still has no idea WTF to do.
you can see a large red cable in the 2nd pic in my sig that runs to the left of the batt and down the side.... :sigh:
