Clutch/Flywheel Combo
Old Oct 17, 2004 | 04:25 AM
Ralph's Avatar
TR Balla Donor Supreme
Question Clutch/Flywheel Combo
Well after last nights out and about I came to realize that my clutch is past its prime and time for a upgrade. I didnt want to change it until I upgraded the all the good stuff but my car is slipping after 7ish lbs of boost. I am leaning towards the ACT Street/Strip Clutch kit rated at 372 ft. lb which is about where I expect to be more or less in a lil while. Price $365+/-.
Though my motor came in immaculant condition with 122xxx kilometers, I am figuring to swap out the flywheel while the transmission is apart to kill two birds with one stone. So Im looking for a flywheel option to best suit my setup/goals.
I am shooting for a GT2871R .64 setup with all the bolt on goodness tuned to perfection. I was following a thread somewhere discussing the differences between using a aluminumn vs a chromoly(sp) wheel and apparently the chromoly wheel wins hands down. So it leaves me (budget minded) with 3 options:
CUSCO light weight (10.56lbs) chromoly flywheel
$435+/-
TODA chromoly lightweight flywheel 10.56lbs
$450+/-
JUN Ultra lightweight Chromoly flywheel 11lbs(roughly)
$450+/-
Looking for any opinions/suggestions on any of these flywheels.
TR Profile
Myspace Profile
Old Oct 17, 2004 | 01:39 PM
Ralph's Avatar
Also, I just ran across the Exedy hyper single plate clutch kit for S13/S14 SR20DET. Kit is rated to hold for 500hp application and includeS lightened flywheel. Any opinions on this setup as well?
TR Profile
Myspace Profile
Old Oct 18, 2004 | 05:15 AM
Ralph's Avatar
John, can you elaborate as to why you would choose that setup?
TR Profile
Myspace Profile
Old Oct 18, 2004 | 09:58 AM
Matt Vassallo's Avatar
lifelong learner
because it's the straight up most baller one.
now for the real answer
it has a smaller disc set more inward to reduce the moment of inertia (i think that's what it's called)
its a much better kit, designed to work together, it's good stuff. you just gotta watch out for thowse twin plates, they are serious.
rest in peace tim.
Old Oct 18, 2004 | 10:25 AM
Ralph's Avatar
Yeah I was looking into the differences in the twin plate/triple plate and singles. Single should be good for me, Exedy Hyper Single Plate clutch set it is!
TR Profile
Myspace Profile
Old Oct 18, 2004 | 11:58 AM
lifelong learner
hyper single is good to like 550whp and more
rest in peace tim.
