Irregular Idle
Old Aug 24, 2004 | 07:11 AM
coolcloo1019's Avatar
Uhhh...
Default Irregular Idle
Just started happening a couple of days ago. When I push in the clutch the idle drops to like 400-500 and then will go back up which never really seemed to be a problem. Today when I started my car it wouldn't stay started until i gave it just a little bit of gas. Once started it would idle normally It normally idles about 650-700, should i bump it up a hair or what is wrong? Thanks, Sean
Old Aug 24, 2004 | 07:44 AM
TheLogikal1's Avatar
sounds like you need a tune up. fuel filter, distrib. car and rotor, spark plugs, plug wires, oil change and oil filter should take care of most of the job.
95 240sx
Old Aug 24, 2004 | 09:57 AM
jeffronismo's Avatar
Don't be a quitter...
Damn sean, ever since u replaced your once cam with that DOHC all u have had was more and more problems... WTF?!?!
Originally Posted by satanshatch
"If it's got tits or wheels you're always going to have problems with it" - My father
Old Aug 24, 2004 | 01:06 PM
Uhhh...
Fuel filter, spark plugs, plug wires are new (like 2 months old) and i just changed my oil last week so that takes care of the oil and filter. So all thats left is the distrib. cap and rotor...you think thats whats causing my idle to be dropping?
Old Aug 24, 2004 | 02:27 PM
Matt Vassallo's Avatar
lifelong learner
maf ?
rest in peace tim.
Old Aug 24, 2004 | 02:29 PM
cyanide's Avatar
MAF or IACV?
Old Aug 24, 2004 | 07:56 PM
Uhhh...
Alright, I know what the MAF and IACV are but how would I go about checking them out to see if thats the problem. Any suggestions?
Tennessee Vols
Old Aug 24, 2004 | 09:57 PM
240sxJay's Avatar
Ka24de N/A
You can check buy removing it? You can look for any gunk that may have been built up ...if it needs a cleaning you can use that electrical spraying shit. If you read other nissan forums the 240sx is notorious for having idle problems. What ended up being my problem was the spark plugs i put in...i had bosch +4platnium which would make my car idle like shit, took those out and put in NGK iridiums, problem solved. I take it your not getting any codes? Usually a O2 sensor or Maf would come up.
Old Aug 25, 2004 | 06:17 AM
spoonfed's Avatar
Tha numba one stunna
try cleaning the throttle body with carb cleaner...make sure the tiny hole in front of the buttercly is not clogged.
... content in sig not work friendly
Old Aug 27, 2004 | 10:18 AM
Crazy Eyez's Avatar
Has dyslexia and A.D.D
Ny car did the same thing it was timed wrong but once I got it timed it was fine....damn i think there a SOHC to DOHC curse ever since I put in a DOHC ive had a bad ecu, radiator problems then timing and now a leaky cliutch line....but ohwell its faster
you sound upset.
not enough time starring into the mirror telling yourself how awesome you are today?
