Help me fix my baby
Old Jul 21, 2004 | 05:49 AM
  #21 (permalink)
240racer's Avatar
Just me.
check your maf to make sure connection is good, w/ no h2o or degreaser in the electrical connection.
Old Jul 21, 2004 | 06:26 AM
  #22 (permalink)
agentAndy's Avatar
more class than college
you mean the war that the french and indians were togeather?
that turned into the 7 year war(france and britan) that beef started in 1756. it ended in 1763 with the treaty of paris.
http://www.u-s-history.com/pages/h1180.html
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Jul 26, 2004 | 06:20 AM
  #23 (permalink)
240varg's Avatar
94 rx7
hey guys...i have the exact same problem...it started when i cleaned my engine bay with decreaser then i sprayed it off with water ( i covered the intake) but the next day it started 2 idle real low around 500 or 600 rpm it kept goin up and down up and down....but it stopped doin it like the 3rd day...then i bought a header for my car and i have 2 o2 sencers and the bottom one by my cat did not fit my aftermarket header so i plugged it off ......and now my car doesnt want 2 pass more then 3000rpm's.......does anyone know what the 2nd o2 does???its by my cat
Old Jul 26, 2004 | 06:31 AM
  #24 (permalink)
J-Dizzle's Avatar
Still Addicted to Boost
egr? check your intake plumbling mine did almost the same things for a while because my intake pipe kept popping off the maifold...and check your maf connection , mine just popped off one day and i couldnt go pass 2500 in any gear in bruce b downs traffic>sucked dick
jason
Don't Text And Drive
Old Jul 26, 2004 | 09:25 PM
  #25 (permalink)
240racer's Avatar
Just me.
Default here's the pic...
varg, the maf is part of the black part on this intake pipe just after the filter. make sure all connection there are good and ry.
Old Jul 27, 2004 | 07:21 AM
  #26 (permalink)
240varg's Avatar
94 rx7
i checked...but it looks like it all right...but my car still doesnt want 2 pass more than 2500 RPM's??:
Old Jul 27, 2004 | 08:53 AM
  #27 (permalink)
Matt Vassallo's Avatar
lifelong learner
if your car isn't going past 2500 you ahve a problem with the maf.
Does your car go past 2500? - YES - Delete this thread.
NO
You have a problem with MAF. Continue down
Replace MAF with known good Mass air meter.
Does car now rev past 2500 rpm? - YES - Post Results
NO
Proceed to step below
Check continuity for maf pins from blue ecu plug to maf plug behind drivers side headlight. Fix if necessarry.
Does car rev past 2500 rpms ? - YES - Post results, car is fixed
NO
Reset ECU
Does car rev past 2500 rpms ? - YES - post results, car is fixed
NO
Replace ECU, install consult and read othe codes / malfunctions.
rest in peace tim.
Old Jul 27, 2004 | 09:18 AM
  #28 (permalink)
240varg's Avatar
94 rx7
ok im goin 2 follow the steps....thanx alot
Old Jul 27, 2004 | 09:24 AM
  #29 (permalink)
buck19's Avatar
Forever Broke Nissan
dude you car has like a quarter of a million miles on it and it still runs. ah the good ol KA
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Jul 28, 2004 | 07:26 AM
  #30 (permalink)
240varg's Avatar
94 rx7
thanx everyone...i fixed my car. it was the MAF i had 2 buy a new one
