KA Engine Survival Tip
maxtype240: hey yea mine had a crack in it but it didnt fall tru or anything, its secure now with the bolts but im going to definately remove..
jason
jason
Don't Text And Drive
Is this the piece under neath the valve cover? I have a weird noise that happens at 3200rpm,and im not sure if its that making the noise on my SR. If this is the same part, the one under the valve cover, its safe to take off? I am just checking since I have an SR
1991 Infiniti G20
1992 Nissan Sentra SE-R
1995 Nissan 200SX SE-R
1993 Nissan NX-2000
1991 Infiniti G20
1993 Nissan NX-2000
bryces car about did the same, but he has the s14 ka motor. so the only other thing to go is the rest of his chain guides and his chain tensioner. yep, everything grenaded, the chain is sitting on metal nubs now.
are the sr chain guides the same as the ka? like could i put sr chain guids and tensioner in my ka?
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
the one on my SR broke a lil while back and luckily it didn't fall into any bad places and do any damage.... but i haven't had a problem since
I called my friend ray that works the parts counter at Autoway Nissan about it when it happened and he said that Nissan had posted a bulliten for them to be removed from the KA engines that came in for any kinda service and said that it would be wise to remove it from the SR as well.
Charles, originally "Boosted240"
www.facebook.com/CPRegister
03' Silverado 2500HD 6.0L Ext Cab w/Wheelchair access conversion by Ryno Mobility
