Replacing stock fuel lines on S14?
Old Apr 25, 2004 | 01:01 PM
SILVIA-S14's Avatar
Suck A Turd!
Default Replacing stock fuel lines on S14?
My s14 fuel lines are leaking. I checked top access panel, they were all dry there. I checked the bottom where the three fuel lines go to the hard lines, they were dry there too.
I leak fuel after the car is shut off after being started or driven a bit. It doesn't seem to leak when its running or started. As soon as i shut it off, it will start leaking right underneath the tank. I am sure its originating from the fuel lines in the middle where it curves around the tank.
Anywho, i was searching and searching even the FSM but couldn't find the fuel line size.
But upon visual inspection it seems to me that it is 5/16".
Anyone tell me how much i would need to replace the three in the back and the one up front (upto the fuel filter) so i go order enough??? 15 feet enough?
I will make sure its FUEL INJECTED line and not just fuel line so it can handle the pressure.
Thanks
RINKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Apr 25, 2004 | 03:43 PM
SILVIA-S14's Avatar
Suck A Turd!
http://forums.freshalloy.com/ubbthre...e#Post67645125
Jesse's post from FA....
3/8" which he used for front.........i am guessing its same on the back......as the hard line stays the same size as it goes towards the fuel tank.
RINKU
FOR SALE ITEMS
Old Apr 25, 2004 | 05:13 PM
steve's Avatar
madpom
i have no clue try and call nissan
