legacy of fragile Nissan bolts
Old Apr 24, 2004 | 10:10 PM
craig_302's Avatar
boostmonkey
Default legacy of fragile Nissan bolts
Alright, just how crutial is the bolt that holds down the coil pack on a SR? Earlier, mine decided it had enough and after a few turns, it snapped. I would have expected it if I had over torqued it, but it wasn't even snug yet. Temporarily, I have the coil pack snugged down with a piece of my brother's old altrinator belt and some foam just to insure it doesn't go anywhere. However, I am paranoid about the coil overheating with this temporary configuration.
Suggestions? Comments? Insight? Insults? Any are welcome.
Old Apr 24, 2004 | 10:26 PM
Domestic Disturbance's Avatar
anti-sieze owns ju
and on a technical note....the belt shouldnt be a problem, but i would wrap that foam in a couple layers of foil if your concerned about it melting
R.I.P Bryan Asay
Blonde girl 1: "Whasts a hemi?"
Blonde girl 2:"its a truck for a motor"
4 mechanically inclined guys:"what the fuck did you just say?"
Old Apr 25, 2004 | 04:09 AM
tim's se-r's Avatar
hate edge
just buy an "x-out" kit, its a drill bit, with an x on the other side, it will remove the bolt. and then just get a new one.
it was probably cross threaded if it snapped, and wasnt snug.
Old Apr 25, 2004 | 04:37 PM
aaron1017's Avatar
is not Rotarded anymore!
Hell... I had the bolt/stud on a 1991 Honda Accord shear right off the other day. I was barely tighening down the valve cover nut after changing the gasket. Had to pay $10 dollars at the dealership for the damn bolt!
LS1/T56 Heads Cam 1994 FD
Old Apr 27, 2004 | 11:15 AM
J-Dizzle's Avatar
Still Addicted to Boost
i had a KA valve cover bolt break off in the hole
Don't Text And Drive
