what type/brand of oil?
Old Apr 12, 2004 | 02:09 PM
nismo180's Avatar
Default what type/brand of oil?
alright guys, i am finally fixing my leaking valve cover tomorrow and with in this week changing my oil. what kind of oil should i use? the motor has about 60,000 miles on it and it accasionally gets pushed pretty hard.
also what type of gear oil should i use?
Old Apr 12, 2004 | 02:12 PM
buck19's Avatar
Forever Broke Nissan
i use castrol motor oil. not sure on gear oil. i just got cheap shit since it is an open diff.
does anyone know if the GM syncro-mesh works goods in nissan diffs.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Apr 12, 2004 | 02:16 PM
Ralph's Avatar
TR Balla Donor Supreme
Mobil for engine oil, use K&N Oil Filter or similar quailty. I think Mattback said Vavoline makes a good gear oil, non syntetic(sp).
TR Profile
Myspace Profile
Old Apr 12, 2004 | 02:17 PM
Boostin97SE-R's Avatar
Resident Asshole
i use mobile 1 5w-30 and redline shockproof heavy gearoil in my tranny.
R.I.P Dad.
The greatest man I've ever known.
6/14/43 - 7/11/06 2:24am
Old Apr 12, 2004 | 02:27 PM
nismo180's Avatar
should i use synthetic? and can you where can you buy redline oil. i've only seen it in magazines and stuff, of course i've never gon out and looked for it
Old Apr 12, 2004 | 09:02 PM
craig_302's Avatar
boostmonkey
I use Valvoline 10w30 in my SR. Seems to work well thus far along with the obligitory K&N oil filter.
My own ghetto backyard testing has shown that K&N filters have superior construction. This means no cardboard valves. Only Purolator and Motorcraft (Ford filters made by Purolator) share this feature. Most modern filters are rebranded Frams with cardboard valves that break down. I recently cut apart a Motorcraft filter off of an 03 Cobra and compared it to a cut K&N and it looked very similer. Long story short, K&N first due to the 1" nut for easy removal, Purolator second only due to the nut. Never Fram or Mobil 1 (another Fram rebrand).
Synthetic oil or not depends on if you have a turbo car or n/a. I have a turbo car and it seems to like the mineral oil that I dump every 2000 miles. Synthetic oil seems to be thinner (and as thus adds HP due to less viscosity) and adds hp to n/a cars or cars that were designed with this in mind. For the seals in turbo cars, I am of the belief that synthetic oil is too thin and will case the car to burn oil much like it does in high revving b-series Hondas.
These are just merely my suggestions/experiances. Others have had different experiances...but after 15+ cars, this is what I have found out. Good luck!
Old Apr 12, 2004 | 09:04 PM
Matt Vassallo's Avatar
lifelong learner
Mobil 1 is NOT a fram rebrand. it is in fact, a bosch clone, but with a synthetic filter element.
also:
$30/gallon
rest in peace tim.
Old Apr 12, 2004 | 09:10 PM
buck19's Avatar
mattback. isnt that the mobil 1 oil they use in ferraris? like the oil you have to use or you void your waranttee
Old Apr 12, 2004 | 09:23 PM
craig_302's Avatar
boostmonkey
also:
$30/gallon
Do some research, it is a Fram rebrand if memory serves according to a bunch of online tests. If it is not a Fram rebrand, it is a Fram clone with similer Fram internals. For my engine it is K&N or Purilator ONLY. When you see a failed Fram or Fram clone on your engine, it is scary shit indeed...especially when you take the time and money to build that motor yourself by hand. I am sure I nearly lost a Ford motor or two to the Fram crappiness.
Regardless of if Matt's research and my tired ass research agree, we both agree on K&N as being a good solid filter.
I would use Mobil 1 mineral oil in 10w 30 if I could find it for my SR, but wind up using Valvoiline of the same specs in mineral oil. Didn't know if that information I conveyed was clear.
Old Apr 12, 2004 | 09:25 PM
craig_302's Avatar
boostmonkey
Hahah, anything but Ferrari spec in a Ferrari voids the warranty of like 3 weeks and 30 miles (otherwise known as a year for most Ferrari owners).
